Question about Frigidaire Washing Machines
Water isn't being pumped out. Does have power.
Frigidaire washer #7WT867GH50 Water isn't being pumped out. Does have power.
  • 6,784 Answers
I assume you are referring to a drainage issue within the unit. check the following below.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on May 30, 2009
Frigidaire gallery washer
Not likely that the problem is a pump.. Water usually comes into the machine under the normal pressure of your water supply. Hence, pump problems usually manifest themselves by not pumping the water OUT of a machine. First, check that the electrical power is coming to the machine. If it is.... and your water is definitely turned on..... you most likely have a problem with a switch, or relay or something else inside the machine.. Probably time for a repairman...
Jan 03, 2014 | Washing Machines
Top load washer will not fill with water. Doesn't matter what setting. Other functions appear to be working but no water.
Check to make sure you have power to the pump...if not, trace it back to the relay that kicks the pump on & see if the relay is energized.
Dec 18, 2013 | Frigidaire FGX831C Top Load Stacked Washer...
T02 error code 30
E30 means that the control isn't getting an electrical signal from the water pump. A clogged pump, bad pump, loose connection or a bad control board can cause this error code. The first thing you will want to do is check for a loose connection. Then make sure the pump isn't clogged. Check the pump motor with an ohmmeter and if it is open replace it. At this point the only way to tell if the control or the water pump is the problem is to run the water pump test on this page
Test for voltage at the pump during the test. If the pump is getting power but will not run, replace the water pump and if the pump isn't getting power, replace the control.
Sep 07, 2012 | General Electric WCVH6800J Front Load...
HF error on display
An FH error often means that the machine doesn't see the water coming into the machine (or that the water pressure is too low). If the water has been flowing into the washer for 8 minutes, then the pressure switch is faulty. (The unit shuts off the water flow and gives the error to avoid flooding.) Press Pause/Cancel Twice.
If there was no water to the machine, check that the inlet water valves are open. Check the inlet hose filters for clogs and that the hoses aren't kinked. You may want to change your water hoses in case they sealed themselves against leaks. Also check your incoming water pressure.
If there was water in the washer, check that the drain pump is functioning (and that nothing is clogging the pump filter/coin catcher). Also check that the discharge hose isn't positioned lower than the water level in the washer. This will cause a siphon problem where the water will flow in and out of the washer continuously.
Disconnect the washer from the power and make sure that all of the wiring for the inlet valves, pressure switch, drain pump and flow valve have no breaks in them. Make sure that the inlet and outlet hoses inside the washer are not leaking. (The connection between the hose and the drain pump and the hoses to the washer tub can leak.)
After this set of tests, reconnect the power and check the pressure switch, the flow meter and the CCU (main control board). Replace any faulty part.
You may want to consult a repair person for some of these tests and repairs. If the washer is under warranty, get the unit serviced if the problem isn't in the hoses.
I hope this helps.
Apr 15, 2012 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Washer will not drain
I have the same problem. I changed the pump and the control switch, but it still does not drain the water out. I am about to give up. It sounds like we may have the same problem. I am still waiting to see if anyone knows whats wrong.
Jan 26, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
I have a frigidaire quiet clean I.Water will flow in the washer and it will pump it out at the end of the cycle.It doesn`t circulate the water thru the spinner assemblies to wash the dishes.The soap will...
the spray arm may be blocked see when door is open that it can spin and is any thing blocking the spray arm ,check if any food particles is in spray arm or tower check these areas out first write back if this dosnt work out.thanks
Dec 02, 2009 | Frigidaire Dishwashers
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
