Question about Maytag Neptune FAV6800AW Top Load Washer
Top loading maytag washer leaking water during wash cycle
How do I remove the front panel of a top loading maytag washer?
  • dh1200s
    dh1200s May 11, 2010
    Post to cmarcum,
    You can disconnect the right lid lock and leave disconnected, I have had mine removed for the past six months. I feel you have a problem with the left lid lock. You should post your issue as a new problem not a solution to this problem post. I will place suggestions for trouble shooting and working toward a fix for your OD error code on your new problem post. I too have been confused a bit by the new forum format
    Rich
  • dh1200s
    A little mor info if its a FAV6800AW/FVA9800AW
    The Service Manual for reference. Sears Parts Direct for reference.
    Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
    5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the SM
    President:
  • 1,136 Answers
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
  • n2jpn Jun 10, 2011
    if it is leaking right at the center of the tub and transmission, can that seal be replaced?
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Water leaking during wash cycle. How do you get access to inside
I use a putty knife about 2" inward , between the top and the front panel on each side . Give a good hit on one side while slightly pulling the front panel forewafd . Then do the other side . The front panel tilts foreward and hinges on the bottom with tabs . Then lift to remove .
Aug 02, 2010 | GE WBSR3140DW Top Load Washer
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Leaks during wash cycle. need to get cover off without destroying the washing machine. looks like new now!
at the bottom of the front panel are 2 screws you need to remove ( easier to tip machine back a little to get to screws. then pull the bottom of the panel toward you. as it swings out, the top of the front panel will release. you should be able to find your leak from there. shane
Aug 25, 2009 | Maytag LAT3600A Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
546 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
