Question about Craftsman Garden
Displaced carborator spring-mower starts but immediately chokes off
Carborator spring is unattached, where does it go on an older style Craftsman push mower? I took off the carborator and cleaned it and all the surrounding openings and hoses on our Craftsman mower 4.0 hp mulching. (it does not have the briggs and stratton engine it is about 12 years old). I got everything back on but the mower won't stay running. There is a thin spring under the carborator "opening" switch and it popped off I don't know where it is supposed to connect. I also had trouble getting the governor arm back on and "bent it a little" how straight or tight is it supposed to be? Please be gentle and give simple instructions I am a women and this was my first attempt at mower repair. Thank you. This is the carborator that I asked about. The spring is under the gold plate on top that turns the door open and closed. It is currently in the notched space to the right of the two holes (if you are looking at the picture left is toward my husbands hand, right is toward the narrow nozzle end). Where is this spring supposed to be? does it connect to the governers arm?
  • 1,040 Answers
Connect the spring to governor arm. It should be very lose
Jim
Posted on May 31, 2009
  • Jim Parker
    Jim Parker May 31, 2009
    Thanks for the rating dotwigg88. If you should ever have any questions about drywall finishing/patching, or know someone who does, put your questions to "Tools-Building & Power-Hand Tools"at FixYa.com
    Thanks Again,
    Jim
I need to know please how to put a spring back on my craftsman rotary lawn mower. 700 series Briggs and Stratton. Model# 917.370690
maybe you can find what you need to know at this link. I can't tell what spring you are talking about
http://www.searspartsdirect.com/model-number/917370690/0247/1500600.html?searchType=modelSearch&q=917.370690&searchTerm=917.370690
May 24, 2017 | Craftsman Garden
Where is primer on craftsman platinum push mower
It may not have one. Some mowers auto choke using spring tension on the choke plate in the carb. They open the choke when the engine speeds up after starting.
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Choke on carborator is broke
You car always remove the air filter and use your hand trick. meter the air coming in to the carb with you hand to get it started.(Less air hence "choke")
Nov 06, 2013 | Craftsman Sears Snow Thrower Manual Model...
G'day,was given honda brushcutter 422 that had sat for over 3 years,cleaned plug,magneto,fuel tank,airfilter,carby,exhaust of wasp nest,oil change....new fuel . started after a few pulls with...
In your carborator there is a fuel stop bubble that is lifted up when enough fuel is in the carborator that buble might be broken if i were i would look in the carborator to see if there is any fuel if there is then you probabaly have to replace that
Apr 08, 2011 | Garden
Either need to rebuild carborator or clean it ?
most small lawn mowers have a carborator mounted on the gas tank.
if you take the screws out and look it has a gasket and the gasket will
be bad and need to be replaced also if it is a newwer model it has a
primer bulb that needs to be replaced at same time.
Jun 21, 2010 | Omega Rear Drive Wheel Snapper Mowers
Snow blower won't stay running
ok heres what you do to get your snow blower to keep running.
while you have it choked, and you get it to the running point, turn the cup bowl ajustment in/out a fraction at a time while you move the chock off slowly till you get the right setting to keep it running then ajust the setting once more to clear it up to purrr like a kitten again the vibration moves the screw out to set everything out of wack......
Feb 09, 2010 | Craftsman 16" High Garden Tractor Snow and...
My craftsman rotory lawn mower 6.5 hp self propeled walk behind cuts out afater starting a few seconds . model# 917.377070
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Aug 02, 2009 | Craftsman Garden
Garden Logo
411 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
