Question about Panasonic DVD-S35S DVD Player
The tray disc says LOCK, someone know how to unlock
DVD-S35 DISC TRAY LOCK, HOW TO UNLOCK?
Hold stop on player and power button on remote at same time for 5 sec.
Posted on Mar 31, 2011
Does anyone know the numeric code to unlock the DVD tray inside this Toshiba 19LV61K TV/DVD? There is a disc stuck inside the DVD tray, and the film will play without a problem.
There is no such code to get out the strucked disc. you have to take out it by manual method. If you wish to get some details; check the site linked here. Pull up older posts.
If you insist on a numerical code, and have determined, won't do anything without it, try this alpha numerical code {VWXTB 028103820489} Followed by Menu button.
Good luck.
Mar 24, 2016 | Toshiba Televison & Video
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
Hello, I have jusy bought a HTS3011 home theatre system, but I had try to play a lot of dvd s, and I had an error related to the disc regionin the most part of the discs I tried. Can someone help me? As I...
Hello Patricia -
Please follow the instructions below for unlocking your Philips HTS3011
1. Switch on the DVD player
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the DVD player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Regards,
BElectric
May 01, 2011 | Televison & Video
It is locked and we do not know how to get it unlocked. It states we need a code and we do not have it.
Do you mean it is disc locked or tray locked? If it is tray locked, it may require workshop attention, which could be expensive (depending on the nature of the problem). If it is DISC LOCK, try this:
Up to 20 discs can be locked.
[ Lock ] - To block the playback of the current disc. Subsequent access to a locked disc requires a six-digit password.
The default password is 136900.
[ Unlock ] - All discs can be played.
(You enter the six digit code as above then press OK on remote) (resourced from elsewhere)
Apr 18, 2011 | Philips DVP3982 DVD Player
How to unlock my sony bdps300 blue ray player
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
  • While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
  • After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control.
NOTES:If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode.
Each time this procedure is performed the disc tray will either lock or unlock.
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you.
Thanks for understanding.
Jan 19, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Unlock Sony DVP NS725p
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 24, 2010 | Sony DVP-NS725P DVD Player
Dvd stuck in machine will not play or open to remove movie
there might be something hooking the disc tray that is prevent it from opening.
The solution to this problem now is to, get a screw driver, unscrew the screws on the player, open the player cover so that you can gain access to the disc stuck inside, remove the disc and check for what's preventing the player from ejecting.
Take care.
May 30, 2010 | Panasonic DVD-S35 DVD Player
DVD won't play
Check whether it is a problem for that single dvd. If yes, it is the problem of that disc, not that of your player. If not, switch off the player and let it cool for a couple of hours. Then try again with another disc. You may find that working.
Apr 20, 2010 | Panasonic DVD-S35 DVD Player
Panasonic DVD-S35S DVD Player Logo
386 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
