Question about Optoma HD70 DLP Projector
Changed bulb in Optoma HD70 Projector. Still have lamp failure
Our lamp failure light came on the projector. We purchased a new bulb, changed it, metal switch made the connecting sound, powered up, and still have the orange lamp failure light on. Optoma's troubleshooting manual is a joke. I need real advice here. Can anyone help? Power is not an issue here. My green power light is on and the projector is trying to come on. It tries a few times and then the orange lamp failure light stays on.
  • ktholmes16
    ktholmes16 May 30, 2009
    Right, I saw that. However, don't you need an actual picture to go through the menu prompts to reset the lamp meter? We don't even get a picture. There is no light coming from the projector at all and the lamp looks fine. All we have is the green "on" light and orange "lamp failure" light. Nothing else.
    President:
  • 3,433 Answers
You state the lamo looks fine, yet it is not working?? Hmmmm, confusing. But, We will work with it.Thegreen is letting you know the machine is powered up. The amber lamp says the lamp has failed. Two different things. Ok, somethingsenses current passing through the bulb, or the light/heat it emmits. More that likely the light, through a photo electric sensor. The sensor should be in the close proximity of the bulb, Look around in that area of the bulb. Could you or have you done this? Also, Look for a possible fuse in the circuit. Good luck. There should also be a cooling fanfor the bulb. So a fuse is very likely
Posted on Jun 06, 2009
WHY DOES MY HD OPTOMA DLP 70 TURN OFF AFTER FEW MINUTES?
If you have recently replaced the bulb you may need to reset the lamp counter in the projector menu.
If you have not replaced the bulb, the projector may be shutting down due to over-heating. Check that the projector is clear of as much dust and debris as possible.
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
Optoma HD70 bulb failure
I am betting that the ribbon cable to your color wheel has become loose. Here is a detailed slide show of a similar model so note where the cables are and check each one.
Optoma HD20 DLP Projector DMD repair turning green and flickering
Jun 25, 2013 | Optoma HD70 DLP Projector
I have a Optoma projector HD70 How do you reset the lamp operating time?
hi,
Do the following for reset the lamp hour.
1. Press the menu button
2. Select Options.
3. Select lamp settings
4. Select lamp reset.
5 Select Yes
ok
Jul 08, 2011 | Optoma HD70 DLP Projector
My optoma hd70 projector which is 4 years hold has worked perfectly. However when I switch it on it works for a few minutes, then the screen turns various colours, it makes a funny noice and then switches...
The color wheel sensor needs good cleaning. an optical lens cleaning liquid might help. also clean the fans and vents if you open it. I had to remove the sensor and clean. then it worked.
Jul 01, 2011 | Optoma HD70 DLP Projector
I just put in a new lamp bulb for the second time and it seems that when i use my projector for about 15 minutes it seems to change colors on me like it will freak out and just change colors.. why is this...
Its not the lamp. I had the exact same problem. You need to clean the inside of the optoma from dust. Especially clean the colorwheel and the sensor next to it. Search on google for more on this.
Oct 29, 2010 | Optoma HD70 DLP Projector
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Mar 05, 2010 | Optoma HD70 DLP Projector
How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
Nov 07, 2009 | Optoma HD70 DLP Projector
OPTOMA HD 70
You didn't include much information other than the lamp not coming on. Here are a few things to try, if you haven't already. Unplug the projector and allow it to sit for a minute or two. Try removing/re-installing the lamp assembly. Sometimes especially after a lamp change the bulb/contacts are not properly seated. Ensure the screws are securely fastened to keep the bulb seated. Are there any lights, i.e. power, bulb or fan errors lit? I've had my HD70 since 2006 and use it everyday for my main television. PS3, DVDs and Cable all run through it. I average one bulb per year and about 3100 hrs on each bulb. My last bulb actually lasted 3600. I have tried all the above and each has worked at some point. Hopefully you can have some success.
Jul 04, 2009 | Optoma HD70 DLP Projector
Optoma HD70 DLP Projector Logo
397 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
