Question about Kenmore 22422 Top Load Washer
Loud noise in washing machine
I have a whirpool 90 series washing machine it was given to me by my parents. Ever since I moved it into my apartment it makes a very loud sound after the spin cycle. It almost sounds like a jake break on a semi. Someone said that maybe the shipping rod had not been removed. But as stated before this noise did not start until after I moved it from my parents house to mine. PLEASE HELP!?
    President:
  • 1,136 Answers
Hi, Raise the lid and stick something into the hole to activate the lid switch. Start the washer in spin cycle and after 30 seconds or so, release the lid switch and see if the tub continues to turn and make the rumbling noise. It sounds to me like the block that holds the inner tub has gone bad.
Has nothing to do with the move but, might have just happened.
Please let me know if this is the case or if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
Kenmore 90 series makes a loud noise during spinning and it looks like the basket is loose
On most Kenmore or whirlpool dryers, you have two wheels that have rubber around them. They look like wheels off of rollerblade skates. They simply bolt on to the back, but you have to usually put a large piece of wood to act as a fulcrum as you support the weight of the drum and change out the two wheels. Check with searspartsdirect.com for the parts prior to taking the dryer apart. I had a machine that sounded like tennis shoes were rolling around the drum and fixed the issue by simply replacing these two wheels.
Good Luck
Jul 23, 2014 | Kenmore Washing Machines
Noise while spinning
My 90 series kenmore washer. At the start of spin,makes loud clicking noise while it spins. Than it stops after a min. I changed the coupler. Still makes noise.
Jan 05, 2014 | Washing Machines
Wahing machine makes a loud banging noise
This could be due to pending failure of the flexible joint beneath the tub
Jan 22, 2013 | Kenmore Washing Machines
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Loud noise when stoping
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Kenmore Washing Machines
Series 90 washer loud clicking during Slow wash cycles, Fast OK.
Turned out to be a loose electrical connector near the motor.  Plug was re-connected and secured with a zip tie to prevent another disconnect.
Apr 03, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 22422 Top Load Washer Logo
138 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
