Water won't stop filling washing machine.
Washer keeps filling with water til over flowing. Have to manually turn water off and set the dial further on to start the agitating cycle.
  • lmn_808 May 30, 2009
    Thank you, gurus, for the advice.  If something comes to mind after knowing the make (Maytag) and Model (LAT9205), please post your thoughts, and also the level of difficulty such a project would involve? Many thanks, again.
    P.S.  My daughter just advised me that the washer is working perfectly.  However, we encountered an uh oh situation yesterday, where the washer wouldn't spin.  After I poked around the areas where the little nibs on the washers lid connect with the holes on the washers top loading area, it began to spin after closing the lid.  2 problems in 2 days feels like this machine is trying to say something.  Please give me your thoughts...mahalo
    President:
  • 1,136 Answers
Hi, Will the water shut off if you turn the timer off or unplug the washer?
If it shuts off when power is turned off to the washer, you need to look into the water level switch. If turning off power to the washer will not stop the water, you need to change the inlet valve.
Please let me know so I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    You are welcome.
    President:
  • 2,992 Answers
Your machine needs a water level switch. It's not a very expensive item and fairly easy to replace for a do-it-yourselfer. If you don't feel up to it, an appliance tech could do the repair for less than the cost of new washer, probably an hour labor plus part and trip charge.
You don't give your make and model so I can't be more specific. If you want to give it a shot, search the Web for "water level switch replacement" and your machine make and model. You'll find many sites with parts and how-to information.
  • May 31, 2009
    I guess I misread your original problem and only noticed the bit about manually advancing the timer. Maytag317 is right on about the inlet valve if the machine keeps filling if the power or timer is off. There should be filter screens in the water supply lines to keep out debris that could cause the valve to stick open. These can be in the valve itself or in the ends of the hoses where they connect to your water line. If these are missing they can lead to a stuck valve.
    The machine not spinning is because of the lid switch. If it's not working and the machine thinks the lid is up, it won't spin. On some machines the lid being up prevents any motion. Sometimes soap scale and other debris can build up and interfere with its operation.
    Neither of these problems is unusual, and it's just coincidence they both seem to have hit your machine at one time. Neither is a major repair. The cover has to come off to replace the parts, so you may as well have both problems fixed at once. It's still less than a new washer.
    Aloha!
  • 35 Answers
Check water level Switch make sure the hose is connected properly.
If it is loose simply cut about 1/2 an inch from each end.
Reconnect and make sure there are no kinks on the line.
Check the water level with a ohm meter.
Make sure the water valve shuts off when the timer is off.
(if the water valve does not shut off even with power off, replace it)
http://www.pdxappliance.com
Posted on Feb 27, 2010
Water will not turn off.
The washer that stops the water has broken and needs to be replaced.
May 27, 2013 | Kenmore Washing Machines
Whdre526e1ww won't stop filling
Does the washer continue to fill if you turn the dial to the off position or does it keep filling when starting a load?
Oct 17, 2012 | GE WDSR2080D Top Load Washer
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Jan 11, 2012 | Frigidaire GLTF1240A Front Load Washer
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
278 people viewed this question
Top Washing Machines Experts
