Question about Philips 60PP9401 60" Rear Projection Television
Looks uneven almost like 3d
I have a rear projection tv,over night the picture got weird,you can see the picture good but it looks almost like its in 3d,the green picture looks to be over farther then the other colors,,the 3 lens all lite up good and do have pictur in them,,it just looks almost like its 3d,,if any one has any advice i would love to hear it thanks in advance
The lenses might have moved out of line - with power off give a gentle tap to the side of lense suspected of this problem. (power off) then switch on if there are changes then you have found your problem.
good luck
Sher
Posted on Oct 20, 2009
Why does tv have double color picture appears in three d?
u need a tech to reset the tv convergence problem the cost depends with the tech and your area check with your nearest tv repair shop
Jul 11, 2013 | RCA P61930BL 61" Rear Projection...
Picture is weird.It's 3d looking,doubling pictures and words??
Its going to depend on the model number of the set---is it a D52 etc?
Nov 02, 2012 | RCA Televison & Video
My TV (module # KP-57WS500) is in a weird double vision view as if it is in 3D. with blue,red, colors. top and bottom of the screen also curve into the center of the tv. worked perfectly fine night...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 24, 2010 | Sony KP-57WS500 57" Rear Projection...
My Sony kp57hw40 looks like it is in 3d after it has been on for awhile it goes back to normal
It starting to died.It will happen for good.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have pictures colors shadows or 3D picture look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The Shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-57HW40 57" Rear Projection...
Looks 3d,bows in the middle
You must replace conversion IC's (2)
Part number: STK 392-xxx
Also check resitors in circuit for>>open
easy repair!
May 19, 2010 | Sony KP-43HT20 43" Rear Projection...
Picture has double exposure as well as curved, color also is distorted with pink at the top of screen. It is on a good surge protector. It was fine last night and just started it this evening when we...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Samsung PCN5425R 54" Rear Projection...
3d affect
have the dm board checked
Sep 08, 2008 | Zenith R57W46 57" Rear Projection...
Philips Rear Projection TV 43PP9202 Picture looks 3D
You need to replace both convergence ICs they are STK392-120 you will also need about four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. here is the link.
http://servicemanuals.vstore.ca/
Jul 20, 2008 | Philips 43PP9202 43" Rear Projection...
Picture problems
We called a tv repair guy. It wasnt anything we could have fixed easily. Thank though.
Mar 31, 2008 | Mitsubishi VS-60611 60" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Philips 60PP9401 60" Rear Projection Television Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
