Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Deleting files from hard drive does not free up more space. only ~170gb have been put onto it, but it reports only ~72gb available
My 500gb hard drive reports approximately 72gb available, though ive only put about 170gb onto it. deleting files does not free up more space
  • 822 Answers
Deleting files giving free space.
Posted on May 30, 2009
How do i go to drive c
Click Start, then Computer. It will show you how much free space you have on your C: drive. All "hard drives" need at least 25% free space to operate efficiently.
Run CCleaner and see how much space it frees up.
If the C drive is still short on space, you will need to uninstall any programs you no longer need, and delete any files you no longer need.
May 18, 2014 | Lenovo N586 7540XF1 Laptop A6 2.7GHz 4GB...
Iomega 1tb ext harddrive says its fullll when it should have about 500gb free ???
Click on start, then computer, and then double click on your Iomega drive. See what is on there that is taking up all the space.
Also check and see what windows reports for free space and total space available
Dec 07, 2013 | Computers & Internet
500gb Seagate external. Shows in Device Manager, but 0 data, 0 space available: had three partitions, lots of data. Now shows status RAW. Is there anyway to access, or am I stuck with a recovery servi
Do a google on "seagate LBA 0" there are some diy options.
If it's just a case of bad sectors these guys can help you do remote data recovery over the net. http://FreeDataRecovery.us
Sep 26, 2012 | Seagate FreeAgent Pro 500GB External USB...
Free Local Disk
If you are trying to free up space then get CCLeaner. It will delete a ton of junk files with the click of a button and it's FREE.
http://majorgeeks.com/CCleaner_Standard_d5125.html
Jun 25, 2012 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Cannot delete files from D drive
Try deleting the files inside the folder first
If not
Copy some of the files off the drive onto a DVD or two that will make working space on your hard drive
Jun 25, 2009 | HP Pavilion DV2740SE Laptop
Low capacity problem
Mostly this is affected by match used to construct the drive geometry. The narrative below is courtesy Tiger Direct of Canada and is their copyrighted content.
When we ask our customers if an Answer is satisfactory, the requested rating is four diamonds for a thorough answer. Hopefully, you will find the below content achieves that mark.
  1. The way size is calculated and displayed.
  2. Any "Partitions" on the disk will change the total in a specific partition.
  3. Hidden files and folders decrease available space.
  4. Compression increases the apparent size, but not the physical size.
  5. Drives larger than the OS or Drivers natively supports.
hddsizescreen.jpgFirst, the definition of a megabytes (or gigabytes) is a unit of data storage capacity measured in 1,048,576 bytes (or 1024KB). The larger the numbers, the more apparent the size difference will be when listing the size as megabytes (or gigabytes) versus bytes. Actually, both numbers are correct. The noticeable difference is due to the 1024KB definition of a megabyte. This is why a 95.3GB hard drive can also be listed as having 102 billion bytes of total space. Just think of it as "round off" In the screen shot at right: The first number is the total number of bytes, the second number is based on the number of megabytes or gigabytes.
Second, some computers have a non-DOS hard drive partition that is used for features such as Save to Disk, Hibernation, or Recovery. This partition is not normally reported by the operating system, although it can be viewed using a disk partition utility. This is very common on desktops and laptops. NOTE: Partition information will be created or formatted automatically during initial system setup and a system recovery.
Third, by default, all system files are hidden and cannot be seen. This may adversely affect the reporting of available hard drive space. You can set your Folder Options so you view system and hidden files and folders, but do be careful as changes to system files can adversely affect your system.
Fourth, if you turn on Compression for a drive, it will increase reported free space and used space, but since compression is based upon the actual contents, this number is not fixed, but will change as files are added or changed.
Fifth, older operating systems did not support some of today's larger drives, so the total space reported may be much smaller than the drive specifications.
It is also worth noting that bad sectors are corrected by your operating system and can change the total drive space, free space, or used space as well.
So as long as a drive is reporting a value approximately close to the specification value, you can be comfortable that you received the right drive and that you are getting to correct data storage. Of course, tuning of your drive's partitions and options can yield optimal values, but this is not something for the average user to explore.
Jan 15, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Free space?
Try formatting the flash drive
Jul 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie Porshe 500GB
if it's a fat32 formatted disc, then it won't recognize a 4GB file. that's the nature of fat32, i'm afraid.
Sep 06, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
440 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
