Question about Bose 301 Series V Direct/Reflecting Speaker System - Black
Silenced Bose 301's
I turned up the volume on my stereo too high and my Bose 301's went silent. I turned off/on my stereo booster (350 Watts) and i get "sound" but sounds like AM radio then goes silent again.
  • gmarshall64 May 31, 2009
    Cant be the wrong connection as this stereo has been playing solid for 5 months +. The only change is too much volume input and the speakers just "cut out".
  • 822 Answers
Wrong connection.
Posted on May 30, 2009
How do i get my speaker to work at high volume with out them cracking,popping destort
If you are using the factory installed speakers they aren't made for the wattage output of your receiver. Factory stereos only put out about 5 to 10 watts. If you want to play it really loud you need to replace them with speakers that have a higher wattage that what your receiver puts out, which is a maximum of 50 watts
Aug 23, 2015 | Kenwood KDC-248U In-Dash CD, MP3, WMA Car...
Bose speaker service
If the speakers are making a crackling noise at high volume yes, you need to take them in for service. The main problem that I have found to cause this issue is faulty instillation from the factory or using the system at a high volume with music. If it were me, I would send them in to Bose. They are a great company and will work with you to fix the issue.
Aug 17, 2012 | Bose 301 Series V Direct/Reflecting...
What receiver would you recommend for bose 301 speakers? someone suggested Onkyo 7.2 Channel 3D-Ready Home Theatre Receiver HTRC270
Anything with good clean power not overdriven will sound just fine.
If you can afford them and have the space for 5 (or more) I'd highly recommend them. Matched full-range speakers will yield the best surround experience. You might not even need a sub.
I have several iterations of 301's up to Series IV and they sounded awesome as fronts but I prefer my 901's so the 301's serve aurround duty now.
The manual prescribes >>>
301: Compatible with amplifiers and receivers rated from 10 to 150 watts per channel. Rated 4 - 8 ohms
Mar 06, 2011 | Bose 301 Series V Direct/Reflecting...
Which model of amplifier will match the Bose AM 10 series4
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
I hope this helps - good luck
Sep 14, 2010 | Bose Acoustimass 10 Series IV Home...
Sir my speaker bose 301 series v and i connect to amplifier pioneer 5 x130 watts.also i have center speaker.bose vcs10.is this compatible to good music and movie....
If they're all Bose 301-5's then you have the rare instance of matching speakers all around, so when sounds move around the room in a movie they don't change. I'm envious because even though I have Bose 901's (front) and 301's I don't have that exact match you have. The 301 sound is very good to my ears.
I assume you have them all set as LARGE speakers in the Pioneer, since they are capable of good bass and the parameter is more about Bass response than actual size.
If you added a subwoofer (which you may not need) you might fill in the lowest bass and effects channel.
Aug 19, 2010 | Bose 301 Series V Direct/Reflecting...
2005 Chevy Silverado Bose stereo operators manual, how do I set the EQ presets?
My left front speaker sounds distorted at low volume but sounds ok when I turn up the volume.2005 Chevy silverado bose stereo and speakers
Apr 30, 2010 | OEM Systems Car Audio & Video
Latest model surround receiver for bose 901 speakers VI
I can think of no reason any amp pushing 120 watts would not work with 901-VI's. They're very efficent and will probably play louder and cleaner than you would ever need. As I recall, my old series IV's have no maximum amplifier rating specified, but I did blow up a bridged Carver M-400 Cube (pushing 400 watts to one speaker with a DVD-Audio of Yes - Fragile cranked dangerously high) with them. I'm convinced my speakers are indestructible in any home application.
Keep in mind that whatever you decide to use as your control/amplifier section, a pair of 901's need a dedicated stereo amplifier. I suspect you're thinking surround sound so a receiver with separable preamp/amp channels, due to the Activbe EQ, would be needed and as far as I know they don't exist. A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. 120 clean watts is good. I'm using only 110W for mine.
A Carver M-200 is a fine, efficient amplifier that would have you cooking just fine (2x100W).
Mar 20, 2009 | Bose 901 VI Main / Stereo Speaker
VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Dec 28, 2007 | Bose 3 2 1 GSX System
Bose 301 Series V Direct/Reflecting Speaker System - Black Logo
370 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
