Question about Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
I have been using my PS3 and Toshiba HDTV with a HDMI connection for about 6 months with no issue. Today I turn it on and the TV states no video input. I have tried a different HDMI cable and the original cables for the PS3 still nothing. I have connected a DVD player with the HDMI cable to my Toshiba, no problem. I have also tried the other HDMI inputs on my Toshiba and I only get audio no video. I have moved the PS3 to my TV upstairs and connected it, it works fine. Any other suggestions? The communicatoin between the two products seems to have stopped. no video trying to go to hdmi now i do not have any video
    Problem Solver:
  • 6 Answers
The problem is with your PS3 itself.
If it's still under warranty, take it back.
Posted on May 30, 2009
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
My Toshiba 62HM95 DLP TV does not work with my PS3 via HDMI or Component cables. Is the TV not compatible or is something wrong?
hello, unplug all the cables from you ps3, turn the power off on the ps3 then turn it on press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleep relase the button, also turn your tv off then on again, when your ps3 comes back on plug the hdmi cable into your ps3 and then into your tv hdmi 1 on the tv go into the menu find hdmi click on this you should get a picture and sound hope it works
regards
shaun
Nov 22, 2010 | Toshiba 62HM95 62" HDTV
My Toshiba 57H84 has stopped picking up my PS3 through HDMI
try holding your finger on the power button(next to disc eject) for 5 secs
May 24, 2009 | Sony PlayStation® 3 (60 GB) Console
HDMI ports are not working
Try using the cables that were included with your PS3, (yellow, red, white) when you see your PS3 on that input. Plug in the HDMI cable. There should be something saying that an HDMI is detected and if you want to use it. Check the HDMI input on the TV and see if you see anything. The other thing that you might want to do is do a firmware update on the PS3. sometimes there are compatibility issues with HDMI
Apr 19, 2009 | Toshiba TheaterWide 46HM94 46" Rear...
Surround sound for ps3 with a hdmi cable..
you need a HDMI connection for your stereo. HDMI is an all in one cable so if you don't get your sound in/out you need to hook up to just the RCA's, if you get a reciver that has an HDMI input you will solve this. then you go HDMI to Reciver then HDMI to TV
Mar 12, 2009 | Sony PlayStation® 3 (60 GB) Console
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
540 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
