Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
BMW door seal?
How to replace a door seal on a 2002 BMW 325I, left front?
    Problem Solver:
  • 19 Answers
Make sure you have the new one on hand also the glue you can pick up the glue at a local autoparts store. Now lay the new door seal out in the sun while you are taking the out one off so that its warm and stretches easy, once the old one is off clean the railing that holds the gasket with rubbing alcohol on a rag, then apply the glue as you put on the gasket
Posted on May 30, 2009
Oil came from my mixer
You have a bad gasket in your mixer, the oil inside from KA is 6 oz. and the oil is due to separation, as KA uses a food safe vegetable based grease and after periods of non use it separates, liquids from solids, and leaks when the gasket seal goes. It is a messy fix but fairly easy, ereplacmentparts.com has a video on it. hope this helped
Feb 16, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
K45ss mixer works fine except when whipping cream there are small black specs appearing in the bowl that probably have gone unnoticed with darker mixtures. I suspect some type of oil leak
Yes this is probably a oil leak. it can come from two possible location one of which can come from the transmission gasket that goes around the mixers center seem, if this is broken, worn or improperly seated it will need replacement. part number for the transmission gasket is 4162324. another possible location is around the cirrcular mixing gear at the front of the machine. if the seal inside the unit are damaged or worn this can cause oil to leak striaght down into the very food you are preparing. part number for the seals are 3180163. there are 4 of them, and they would require taking apart the whole unit. hope this helps.
Thanks
Sep 27, 2009 | KitchenAid K45SS Classic Stand Mixer
Hobart mixers A120 & A120T.. has an oil leak. Need Seal kit/repair parts info and type of oil to replace.
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
Jul 17, 2009 | Hobart A200 Stand Mixer
Oil leaking from shaft after wew moved it
Oil seal around the shaft probably dried up. Before replacing, try penetrating oil at seal, wait a day; if no better, replace seal.
Jun 25, 2009 | Hobart H600 Stand Mixer
Oil leakage
Is the oil leaking down the beater shaft?Remove the silver drip cup,3 screw's one in the midlle,one on the right and one on the left.Once you drop the drip cup if it's filled with oil then you may need the seal's in the transmission replaced.
Mar 14, 2009 | Hobart A200 Stand Mixer
Bmw 325i engine number
The serial number is located on the lower left side of the block, toward the front.
Feb 17, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Oil leak on A200
OK guys, let's try to solve your common problems first then the rest will become clearer.
The Hobart A200,,,,,,,, does not use oil! It uses grease! If you see oil, it's because the grease is separating the oil in the grease. Both machines have not been serviced for at least 5 years. That's about the lenghth of the lifetime of most greases. I recommend that you call Hobart and ask about their tech. rates. All bearings should be checked carefully for wear, as should the worm gear, seal, and the Bronze gear that it turns. The Planetary (mixing part), should be removed as well, cleaned. and inspected. Replace the seal on the planetary and on the mainshaft. Removal of all old grease is required, as it's no longer doing the job it was designed to do, will result in advanced wear, and is the actual source of your problems. The seals were designed to seal grease, not oil.
If Hobart is too pricey for you, and they are for many, try to find someone from a wholesale restaurant equip. place who has rebuilt these machines, or find a repair shop who have experience with this Hobart model. If you'd like to tackle the job yourselves, go to www.hobartservice.com. Register for free, then find the files that match your mixer model and ML # and download the parts files for it. These exploded drawings will be very helpful with your task.
Either way, these mixers need to be opened up to remove existing oil and hardened grease, especially the oil! The planetary must be removed to drain any oil out of it and to regrease it. If you can get the oil out of the mixer, a short fix would then be to simply regrease the the mixer and put it back into service, leaving the existing seals in place. Don't forget to wipe out the shiny ring on the planetary, if it too has oil in it.
There is no seal at the hub. No seals can be tightened. The oil leak underneath the mixer comes from the motor shaft seal at the transmission case where the pinion gear enters the trans., it flows down into the mixer support column and drips onto the floor or counter, again, because of the breakdown of the grease.
If you tackle the job yourself, find your local Chevron Distributor and get several tubes of the approved grease, namely, Chevron FM ALC EP NNGI 2. Chevron p/n 230204-000. If you've found this solution helpful, please rate it as fixya!
Good Luck! ricardok45
Jan 19, 2009 | Hobart A200 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
Aug 24, 2008 | Food Mixers
Hobart h400
Greg,email the pics--there is a oil/grease flinger that can be installed if the model is right.I need the serial #,ml #.
Jun 03, 2008 | Hobart A200 Stand Mixer
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
610 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
