Question about Sony BRAVIA KDL52XBR2 Television
PC monitor driver for Sony KDL52xbr2 rgb connector.
I have a Sony KDL52xbr2 hooked up to my PC with a rgb connector. Is there a driver available on the market that will enable full screen viewing of the picture? Right now it is just a 28''x22''on the TV viewing area.
  • 822 Answers
Install original Graphics driver. its only display settings in your pc.
Posted on May 30, 2009
Hdmi instructions
Hi Kelly,
I believe the Sony Trinitron WEGAs do not have an HDMI connection on the back of the TV. If they do it would be labeled as HDMI input below that familiar looking HDMI narrow horizontal connector. But I believe what you have is the RGB connector which looks like three round female connectors which are color coated Red Green and Blue. Now these RGB connectors are a form of high definition but it's not a direct connect for for your HDMI DVD player or your XBOX 360 or what ever you want to hook the TV up to.
You'll have to convert you HDMI to RGB. you can still purchase DVD players with RGB outputs but if you already have a device that requires a TV with HDMI, you can buy a converter. Go to RadioShack or BestBuy or search online for a HDMI to RGB converter cable . It should look something like the picture below.
RED GREEN AND BLUE for video. And then the white and red connectors that are banded together are for your audio.
Good Luck
Dec 12, 2014 | Sony FD Trinitron WEGA KV-32HS420 32" TV
How do i connect my soni bravia television to internet
Hook up a computer to it. The tv could have an hdmi connector or monitor connector (check the back of the television to see which type of connectors you have available) so just plug a cable in from your pc to the tv.
For sound, a simple computer cable plugs into the headphone jack of the computer to the back of the television. If you have a PC, you may have a series of connectors for stereo surround sound systems (like a sound card). I use a simple jack that plugs into the headphone jack (stereo speaker jack) and also plugs into the pc audio in port on the tv. Now I just select the input (pc) from the sony menu and select the option for sound input and voila. As long as the pc is connected to the internet, your tv is your new monitor.
Feb 23, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Connected laptop to hdtv via rgb lead but no sound from 2nd monitor(tv)
Sadly, RGB cannot carry sound. In order to hear the laptop sound on the television, You'll need to get an 1/8" headphone connector to RCA (White and Red plug) cable and connect it to the same input as the video is plugged in.
Aug 23, 2011 | Sony VAIO VGN-N130G/W Notebook
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
I am trying to hook up my dell xps all in one to my sony tv. the tv has a rgb pc hook up but my computer dosent
Judging by the TV with a RGB hookup, I'm sure that it has S-video. So does that motherboard...
Hook it up using S -video (cheap at WalMart), then go to Display properties.
Choose Advanced, then the Intel Chipset.
Choose the TV as the Primary and your TV will become your monitor
Jun 24, 2009 | Dell XPS One Desktop PC RED-20" HD...
I have a Sony monitor model GDM 20 E01 defected ,need another
maruan, That's was a nice monitor,, yes there are some monitors that still use the RGB BNC, but your computer still has a standard monitor connection or DVI from the video card, a new monitor will come with a cable.  Prices are down now on LCD's - the all-purpose LCD that are PC and TV compatible have those connections but they aren't as nice. randy320sgi
Jan 09, 2009 | Sony Computers & Internet
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
RGB NO INPUT SIGNAL
RGB stands for Red Green Blue. Your monitor isn't getting a video signal.
First, look behind your PC.
Pull the video plug and check the pins.
The should be three rows of them. Make sure none of them are bent over.
On the back of the PC, look at the connector socket you just pulled the plug out of. Is there another like it? (15 holes, 3 rows of 5)
If so and the original doesn't work, switch the plug to the other.
Put the plug back in and screw it in tight.
Reboot your PC.
Hope this helps,
Mike
Jul 12, 2008 | Computers & Internet
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Sony BRAVIA KDL52XBR2 Television Logo
280 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
