1990 Ford F150 Logo
Posted on May 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Truck tries startingI have a 1990 Ford F150...won't start. I have fire to the top of the distributor and to the button on the bottom side of the dist, cap but when i put it all back together I get no
Had a no start issue replaced solenoid and starter then all wires as well ran great for one night now it tries to start even when the ignition turned off and keys pulled ..... could this be the ignition switch in the stearing column??? I have a 1990 Ford F150...won't start. I have fire to the top of the distributor and to the button on the bottom side of the dist, cap but when i put it all back together I get no fire to the plugs...HELP
  • Dennis Mulford
    Dennis Mulford May 11, 2010
    sounds like you have a short in the power wire from the seloind too the starter
Jason Phillips
Level 3:
President:
  • Master 500 Answers
  • Posted on May 31, 2009
Jason Phillips
Master
Level 3:
President:
Answers
500
Questions
Helped
180255
Points
1298
I doubt it's in the column... check the wires on your starter again, if they rattled loose and are touching they will crank the starter
I replaced starter on 1989 f150 5.0 now have no spark
Mike, Check for diagnostic codes. Check fuses/relays,wires/plugs for pinched,damage or corrosion. Could be a lot of things like distributor armature, cap, rotor, stator, ICM, coil,spark plugs,wires, make sure ground is good to distributor. Use the attached forum links,instruction, guides to help diagnose ignition spark problems, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
No spark replaced all ignition parts 1990 F150 Ford F150 Forum Community...
Engine Spins but No Start No Spark
Engine Won Start No Spark
Code Reader 80 96 Ford Bronco
Resolved 89 Ford F150 302 Won Start HELP
1990 FORD F150; 351 WINDSOR 5.8 V8 ENGINE; HAS NEW DISTRIBUTOR COIL AND IGNITION CONTROL MODULE STILL WONT START
crankshaft position sensor is bad. it uses this sensor to tell the computer when to make each plug fire. no signal no fire.
3answers
Will turn over without fire, replaced brain and the ignition coil
bet on the module,if it's tfi it's on the side of the dist.85 could be either way,may be the older fender mounted module.
If it's dist. mounted Ford recomends replacing the pick up coil also. There is a wire with a plug on the tfi's ,you remove the "cap" to set the timing,just 2 wires with a gray cap on the end.Maybe that's the wire you mentioned.
2answers
Replace module on dist also relace coil engine starts with a power boost from a outside source but will not start without a boost battery seems ok
Try the "Pick Up Coil" its located inside the distributor, you will have to disassemble distributor to replace it, if you don't want to deal with the hassle just replace the distributor with a used one. I have a 1990 f-150 that was having the same problem, after replacing several parts I finally found the problem, Pick Up Coil. Good Luck.
1helpful
Ned to now wat the firing order for dist cop shood be for a 1987 ford f100 pick-up truck 300sixcylender stick shift model#333
The F100 ended in 1983, so there is some confusion on your 1987 Ford F100. The F150 started in 1983 and was available in 1987, but not the F100. You have this listed under the 1981 Ford F100 category.
The 300 CID = 4.9L In-Line (Straight) 6-Cylinder.
In order to best answer your question I have included both the 1981 F100 4.9L and 1987 F150 4.9L below. The only difference is with the Distributor Cap Configuration and Connections.
For the 1981 F100 300cid=4.9L:
Firing order:
1-5-3-6-2-4
Cylinders:
(back)
...6
...5
...4
...3
...2
...1
(front)
Distributor:
...(back)
.........4..[.]-clip
...................1
6
................5
[.]....3
For the 1987 F150 300cid=4.9L:
Firing Order:
1-5-3-6-2-4
Cylinders:
(back)
..6
..5
..4
..3
..2
..1
(front)
Distributor:
.......(back)
.................4
.....2
.......................1
..6
.........................[.]-clip
....................5
.......3
.........(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
3helpful
1990 ford f150 5.8 no fire
Remove the ignition module and take to your local parts store for testing. It should be located on the side of your distributor were the wire harness plugs in. This will fix it 90% of the time.
1helpful
Hi. i have a 1987 f150 v8 .will not restart after shutting off
try replacing the ignition module on the side of the distributor(common problem) also take the dist. cap off and poke the pick up module inside the dist.and see if its the consistency of bubble gum,if it is replace the distributor also,hope this helps
2answers
1990 Ford F150 - V8 no spark
have you tried checking the coil? or the ignition control module on the side of the distributor...the coil is cheap but you may what to check the junk yard for the others.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
