Question about Maxtor Hard Drive
I have a external hard drive that doesn't appear in my computer
I have a Sumvision Multimedia Hard Drive. I plug it in and the PC will load the driver but the HD isn't visable in My Computer. As it holds my entire music collection i would be keen to hear if anyone has had a similar problem. If i can't get it working van someone tell me how i might get the files of of the external drive when the PC doesn't see it. Hi Shawn I had the same thing happen to me wierdly on the same day you posted the problem. I was using the Sumvision Zengo with 1TB Maxtor DiamondMax 22 SATA HDD on the pc via USB added some files to it, was working fine then I disconnected it from the PC to watch a movie and it said 'No Hard Disk Found' on the TV screen! It has being saying this ever since and like yourself, when I connect to PC via USB I can see the Zengo hardware active via USB ATA drivers in Device Manager under Disk Drives, but properties show no volume information! How are you doing with a solution? Will it work with an adapter on its own as an external HDD or installed in a PC? I am waiting for some equipment to try this as i have over 800GB on the drive and I'm doing my nut trying to sort it out! Let you know if I sort it out and how I did it! Can you do the same? Cheers
  • 822 Answers
Check rectefier diodes and fuses from hard drive circuit board.
Posted on May 30, 2009
Sumvision cyclone mkv 2 enclosure will not conect to my computer the drivers are missing where can i get them from
From this and several other posts you made on this device (I assume you are the same Anonymous poster), it appears you do not have a formatted hard drive installed in the unit, or you didn't know the computer is treating it as an external drive (even if it calls it an "unknown" USB device. Your computer is looking for the file system in the enclosure. The directions for finding the unit from a Windows computer (written for the mkv, not the mkv 2, but they would probably work the same) are given in the review article linked below. Note: if you don't find any "Unallocated" disk, look in "My Computer" for a drive that isn't your internal hard drive or other usual device. Probably all you have to do is save your media files to this drive and they will be available to play on your A/V system.
Sumvision Cyclone MKV Primus 1080HD media player
Sep 21, 2013 | Sumvision Audio Players & Recorders
SUMVISION CYCLONE MICRO DOES NOT SHOW ALL MOVIE FILES ON EXTERNAL HARD DRIVE
Some video formats may be incompatible with the player.
Your laptop probably has more codecs, so more compatibility.
Try a program like Video Inspector to see formats of different files.
Nov 20, 2017 | Sumvision Cyclone Micro 1080P Upscaling...
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
Hello, I formatted my external hard drive Samsung G2 HX-MU050DC and i lost the drivers. I can not find drivers. Can you help me please? Because i can no longer read the files that are on it. Thank you...
According to the microsoft site your external hard drive which is the Samsung G2 HX-MU050DC doesn't need any additional software it is automatically installed when connected..Maybe try to connect it to other USB port I preferred you connect it at the back of your CPU..If this doesn't work try to connect your external hard drive to other computer if it still doesn't work. sad to say but the problem is your external hard drive..
Jul 06, 2011 | Samsung G2 Portable External HX-MU050DC/...
Got a Sumvision External 2.5 Hard drive for over a year now and today i pluged it in as normal and got the following error messages - using windows 7 also tried it in XP and it doesnt recongise the hard...
Hook up that external hard drive to another computer that you know for sure the USB ports work properly. If you still get the same error message or the drive is not recognized then that means the hard drive is bad.
If the hard drive is recognized properly and you can access the files then that means its an issue with the operating system.
May 14, 2011 | Computers & Internet
Hallo. My simple drive hitachi 1TB 96300-41001-170 dont appear in my computer. I need driver but i cant fint it.
This should be plug-n-play. Have you tried restarting the computer with the hard drive plugged in? If that doesn't work, I would return it.
Apr 14, 2011 | SimpleTech 1TB SimpleDrive Pro Duo...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
I cannot get an external hard drive to work on mac
sounds like the Hard drive is not formatted for the MAC
Mar 23, 2010 | Computers & Internet
look for the drivers in google .. just type in the make and model of the hdd and put drivers at the end
May 28, 2009 | Computers & Internet
Philips external hard drive cannot be found
Uninstall the drivers for your external hard drive on your mac. reboot your computer then install the drivers back and plug your external harddrive back to your mac
Dec 20, 2007 | Computers & Internet
Maxtor Hard Drive Logo
280 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
