FixYa.com
Tags:
NEC 166MHz IC CPU
What Type of Socket does Pentium 166MHz(non-MMX)...
By Putty - usenet poster
I have an NEC Ready 7022 that supports intel speed up to 166MHz. I currently have installed  a P100. But my problem is that my motherboard is a SOCKET 5 motherboard and would like to know what type of socket does a Pentium 166MHz uses. Also the Voltage. Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 09, 2005
Thanks for Trying (70)
Kim1
Kim1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
ok ... i appreciate the info ... but ... where can i find a non-mmx pentium chip that will fit my socket 5 ... i have currently a p75 in a Acer .. Compudyne machine and would love to find a cpu that i can upgrade with ... HELP .. thank you  katy
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
http://www.compgeeks.com/cgi-b in/details.asp?cat=Mboards&sku =205-6166
Intel Pentium 166MHz CPU by Intel $81.00
http://www.pricewatch.com/attd ocs/3cat.htm
http://www.krex.com/cart/prodl ist.ptml?ses=TnBVLb5U&cat=CPU& subcat=In...
PENTIUM 166 MHZ CLASSIC NON-MMX
Item:   CPU-166 $55.00
===============(o o)========================
===========oOO==(_)==OOo======­==============
megabr @cyberdude.com
Not an Intel Employee
Not a Microsoft Employee
Just a User.
Your Mileage May Vary.  :)
===========ooooO==Ooooo=======­==============
=============\_)==(_/=========­==============
Solution #3
Not Rated (0)
Gary10
Rating: 0%, 0 votes
Socket 5 supports the OVERDRIVE MMX 166 part.  You should be able
to use that.
Socket 7 supports the Overdrive MMX 200.
The OverDrive(R) Processor Upgrade Guide at
http://www.intel.com/overdrive /upgrade/index.htm
contains a list of systems that are compatible and not compatible
with the OverDrive processors. If your system is not in the Upgrade
Guide.
Intel does not have sufficient information about your system to include
it.
If you want to pursue this on your own I encourage the following be done
before you buy:
1. Run the bios check at
http://www.intel.com/overdrive /upgrade/bios/index.htm and if failing
seek a bios update from the board manufacturer. Successfully passing
this test does not
guarantee that your system is upgradable with the Pentium(R) OverDrive
processor with MMX(TM) Technology.  It is only an indication that the
likelihood of
encountering a problem due to a BIOS incompatibility is low.  There may
be other
incompatibilities with the BIOS that cannot be detected through a
software program.
2. Follow the recommendations on the unbranded system upgrade guide at
http://www.intel.com/overdrive /upgrade/unbrand/index.htm
3. Confirm minimum Socket 7 specifications if applicable. Look at
http://www.intel.com/overdrive /upgrade/unbrand/socket5.htm
Just a User.
Solution #4
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
Im talking about a regular P166, Im not talking about a P166 OVERDRIVE. I want to know what socket a REGULAR P166 must have to be acceptable.
Solution #5
Not Rated (0)
Rachel007
Rating: 0%, 0 votes
Which part of socket 5 did you not understand???
Anything from 75 Mhz to 166 Mhz works with socket 5
Socket 4 is the old 60/66 Mhz original pentium.
200 Mhz Pentiums usually need Socket 7 because of DC current
limitations of early designs.
http://developer.intel.com/des ign/pentium/qit/
ftp://download.intel.com/desig n/pentium/datashts/24199710.PD F
Just a User.
Can you Help with these Processors problems?
Processors
i d number
miss placed product i d number... Answer This...
Processors
email
I'm really disappointed in the... Answer This...
Processors
Processor speed
I have a emachine desk top and... Answer This...
Processors
Window Vista business - window...
i had Laptop Toshiba model... Answer This...
Processors
driver
mass storage controller Answer This...
Repair Service
Find Processor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
