Question about Kenmore 22942 Top Load Washer
Kenmore washer lid switch bypass failure.
I have a Kenmore washer, 70 series Heavyduty. The lid switch is broken. I tried to bypass (per instructions online) by cutting the grey and tan wires and using a wire nut to connect them. Now the washer won't even turn on. What might I have done wrong?
  • 4 more comments
  • amiganderson May 30, 2009
    Thanks so much for the quick reply.
    I did plug something else into the outlet to make sure it worked, and it did.
    What is a ground fault outlet?
    Also, when I connected the wires I wasn't sure if they should be connected so as to make a loop from the switch or to make a loop from the control box. Does that make sense? I tried it both ways, but which is correct.
    I have to run to an appointment, but I will check again when I get home. I'm having company tonight and need my washer!
  • amiganderson May 31, 2009
    ok. I'm back. Let try to clarify to make sure I understand which ends to connect. Once I connect the wires, should I have unconnected wires coming out from the switch or should I have unconnected wires coming out from the control panel? And, what do I do with these ends? Do I put tape on them or something?
    And, does it matter what size wire nut I use? (I bought an assortment)
    Thanks.
    yes. I have cut wires. I cut them just above the little white wire harness on the top of the machine. I connected them there. But, when that didn't work, I started to think that I connected them in the wrong place, so I opened the back of the machine and cut them under the white harness and connected them there.
    I left the green wire plugged in. (I didn't strip it) Should I have unplugged it?
    Original problem: It would agitate but not spin or drain. I could reach under and trigger the lid switch and it would spin/drain. About two years ago, I replaced the lid switch. This time, I saw some posts about bypassing it and figured that'd be easier/quicker. But now I'm stuck.
    I'll go try to put the wire nut on again. What should I do with the ends of the wires that are cut but don't have the wire nut on them?
    no luck. argh.
    Phone might be good.
    I got it!
    Thanks again, so much, for all your help.
    It turns out it was the outlet, after all. I'm not sure how I missed that because I did check it at one point, but, I am thrilled it's all working smoothly.
    Many thanks.
    President:
  • 1,136 Answers
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
I hope this helps you.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • 4 more comments
  • Victor
    Victor May 30, 2009
    Yes it matters. You need to connect the side of the control panel. A ground fault outlet has a small breaker in the middle of it normally used around water.
    Please check the connestion again. Notice if there is a thin layer of insulation still on the wire. Sometimes when you strip the insolation off, it leaves a thin layer.
    I will be here most of the nigth. I try and answer as quick as possible. Also, make sure the timer knob getspulled out all the way.
  • Victor
    Victor May 31, 2009
    If you have not cut any wires yet, just unplug the lid switch. Strip the end off of an insolated wire and insert the ends into the harnes end that goes to the control panel not the end that goes to the lid switch.
    Have you cut the wires of the lid switch yet?
  • Victor
    Victor May 31, 2009
    It makes sense and it should give you same results as long as the harness was still plugged in.
    You didn't hook up the stripped green wire did you?
    What was hte original problem?
  • Victor
    Victor May 31, 2009
    Put the wire nut on the ends that went to the harness on the control side. don't worry about the other ones because there shouldn't be any power to them
    If we need to, I can give you my email address and then we can get phone #'s and talk on phone. (if you are in the states) It might be easier
  • Victor
    Victor May 31, 2009
    Maytag317@Comcast.net please send me an email
  • Victor
    Victor May 31, 2009
    Congrats and You are welcome.
    Please feel free to rate my responses to you so that others as well as myself will know how I am doing.
    Vic
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
I have a Kenmore 70 Series Washer. The lid switch
Bob your an the right track.. remove the two screws ( unplug washer ) pull sw from mount and the wires will folow. they are hooked to a wire clip . with it in hand you can see if sw is cracked or broken .. the new sw will come wire& plug/ you can splice it or remove wire harness and reinstall as you took it appart . the 70 series has a lift up top / two clip in front / use a putty knife . ..mm
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 70 series washing machine won't drain or
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Nov 05, 2009 | Kenmore Washing Machines
The lid switch is bad . You can either replace it , or bypass it under the control panel . Try putting a pencil down into the hole on the top where the lid actuator goes into to see if it drains and spins .
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
Sounds like a broken lid switch. Easy to fix. Heres a schematic.Its # 11. Try part # 285671. Dave www.washermd.com
Dec 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22942 Top Load Washer Logo
1,337 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
