Question about Hitachi 61SDX01B 61" Rear Projection Television
Green spots we have green spots on each corner of our 61 inch screen which are only noticable with white back ground but does not affect the rest of the picture. Can you trll us what this and canit be repaired or ajusted
  • Anonymous Mar 20, 2008
  • masseytl Mar 28, 2008
    I own a Mitzubishi 51 inch projection and I also have problems with green spots....
  • 4,402 Answers
Have you tried doing convergence from the menu? and them magic focus?
Posted on Feb 20, 2008
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I own a 46 inch sony Bravia and have noticed white spots on the corner edges when a black screen is up. Ithought it might have been the surround speakers too close as in the older stlye tv being affected...
All LCD TVs (except the newer LED versions) are back lite on the edges of the TV. Depending on how faint the image is you may simply be noticing the lights. Try adjusting the backlight or brightness.
Without an image this is the best I can do.
Nov 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
HELP Green spots
"eprom upgrade" by a Panasonic tech will solve your problem...
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Green Spot On Screen
IN your statement says tv is second hand and also you tried degausser method also. The problem is permanent magnetic field affected your tv set. So the best recovery is fix one button magnet in the affected area.
Aug 08, 2007 | Panasonic CT-34WX54 34" TV
Sony 61" lcd has bluish spots in screen, any ideas?
Hello, inside the set there is an optical unit with 3LCD panels. Somehow the dust particles came into your set and now the dust is all over the optical unit and 3LCD panels. Only way to solve this issue is to clean the dust. Please contact your Sony dealer. Best regards, Arpi
Jul 10, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Green spot
Easy fix. I had the same green spot problem with PT-52LCX65 and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
May 23, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
161 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
