Question about Goldstar R7003 Air Conditioner
Removal of old A/C
We have an elec. control Goldstar A/C. Does the unit slip in & out like a sleeve? It's been yrs since I installed it & can't remember. We're putting in a new unit.
    President:
  • 2,976 Answers
It depends on how YOU have it installed. It will slide out of the case and the new one MIGHT fit into the same case. This is trial & error. If not, slide the guts out, remove the case, install the new case & slide the new unit into place.
If it's a window unit, just remove the whole thing and replace it.
Posted on May 31, 2009
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Does a window unit have to be in a window? can i put it in the house?
A window unit is designed to have the side with the controls in the space which is to be cooled and the other side to be outside. If you simply put it on the coffe table, blowing at you, you may feel cooler for a little while, but the heat of the fan motor and compressor added to the heat from the outside coil, will raise the temperature of the room.
Best bet is to put it in a window or to have a sleeve made for a through the wall installation.
Jul 19, 2010 | Goldstar R5208 Air Conditioner
How do i change back brakes on 2000 olds bravada same as front
If the rear is disc...here ya go!
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • 2/3 of the brake fluid from the master cylinder
    • Wheels
  3. Place a C-clamp around the outer pad and caliper; tighten the C-clamp until the piston is fully compressed in the caliper.
    • Top caliper retainer, and rotate caliper away from rotor
    • Inboard pad and retaining spring from the caliper
    • Outboard pad from the caliper
To install:
  1. Clean and lubricate the sleeves and bushing with silicone lubricant
  2. Install or connect the following:
    • Sleeves and bushings into the caliper
    • Clip the retaining spring onto the inboard pad and install the pad in the caliper
    • Outboard pad into the caliper
    • Caliper in position over the rotor and install the mounting bolts
    • Wheel and tire assemblies
  3. Refill the master cylinder and pump pedal to attain full brake pedal before Road-testing the vehicle.
May 11, 2010 | 2000 Oldsmobile Bravada
Aftermarket injector kit is slightly different than stock on my 96 5.7L 350 vortec. is there anything i need to do differently? my stock ones clip in to the lower intake and the new one doesn't have clips....
nomoredodge,
Have you tired fitting the old clips to the new rail (injectors)? If this is possible, than great. Also, the sleeves may have to come off, but try it with them on first. If anything seems to be afoul while the truck is running and/or driving (don't drive far) then remove them, and try again with them. If you are in any doubt at all, I suggest inquiring with whomever you purchased the new injectors.
Cordially,
carsandcomps
Guru @ Fixya
Apr 10, 2010 | 1996 Chevrolet C1500
Unit just won't work anymore .
I have a model dh404e with the same problem.I was told it is the main control board inside the unit(not dislpay board) but a new board costs around $60.
Feb 20, 2010 | Goldstar DH504EL Dehumidifier
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
Icing on back of coils on dehumidifier
could be dirt coils or low freon either way needs to be checked
Mar 27, 2009 | Goldstar DH3010B Dehumidifier
Goldstar R7003 Air Conditioner Logo
89 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
