Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Problem with charging.
I have a problem with the camera while trying to charge.
when i put the battery into the charging dock the light blinks on and off, and the battery doesn't charge. usually the light is just solid red when it's charging, but now it flashes on & off. is there something i can do to fix this?
  • 2 more comments
  • efiorav Nov 05, 2007
    the battery doen't charge.
  • shadrack Feb 20, 2008
    when I try to charge the battery the red lights blinks on and off and the battery does not charge. This is twice in an 8 month period. My camera had sat for 1 month between usages. The first time I sent the battery and charger to repair and they replaced them, but did not tell me what was the root cause.
  • Anonymous Feb 22, 2008
    The same thing happened to me. If you need a quick fix go to a Battery specializing store. They may be able to jump start it with a super charger. It sounds funny but when I took my battery in they were able to jump start it and it worked for awhile. But Casio will send you a new one if it is a faulty battery. I eventually had them do that.
  • laughable93 Mar 02, 2009
    When i went to charge my battery instead of the red light being on it kept blinking on and off and wouldnt charge.
Faulty battery, from what I've read. Call Casio and they will apparently give you a new one... I need to take care of this problem as well.
Posted on Nov 03, 2007
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web:
The charging procedure is given with figures on page 6.
Jan 10, 2011 | HP Photosmart M525 Digital Camera
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
Camera wont charge
Hi, if you are using the KLIC-5000 battery try to clean the metal contacts on the battery. Try also to remove the battery of your camera dock your camera on the docking station then turn on the camera, if the camera will not turn on it means the charging mechanism of the dock is defective. Now if the camera turns on it means the battery is defective that is why you can charged it.
Feb 11, 2010 | Kodak EasyShare Z760 Digital Camera
Kodak EasyShare Z760 won't charge.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Jan 30, 2009 | Kodak EasyShare Z760 Digital Camera
Camera won't charge
It's a problem with the battery. It already reached it's life cycle. I had the same problem with my 15 month old casio camera a year ago - flashing red light on docking station. I even tried borrowing a docking station/charger to see if something else is wrong with it.
The only solution for this is to have the battery replace.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Oct 05, 2008 | Kodak EasyShare Z760 Digital Camera
Docking station
I had the same problem. I did need to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Mar 23, 2008 | Kodak EasyShare Z760 Digital Camera
Charging Battery
maybe your battery is dead, put your battery in your freezer for one night and charge it again.
Jan 21, 2008 | Video Cameras
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
76 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
