Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage Door won't close
My 45 pound, 6 year old son decided to go for a ride with the garage door, by hanging onto the manual rope. Since then, the door will open fine, but I have to hold the (wall mounted) button down (remote won't work) to get it to close. It's a Lift-Master 1/3 HP. Any ideas
  • Hannah Schroeder
    Hannah Schroeder Oct 17, 2017
    Wow, your son is really brave to ride up the garage door by hanging onto the rope! My remote won't control mine either, but none of my kids did anything to the rope. Maybe it would be best for both of us to call a garage door service to see if they can fix the problem. http://www.budgetgarageopeners.com.au/ca...
    President:
  • 3,197 Answers
It sounds like the door sensors have been bumped or somehow gotten misaligned. Tweak them until the light on each one is lit and not blinking. They must be pointed at one another.
Posted on Jun 01, 2009
Overhead door opener 555 with manual release won't lockup chain
Sometimes if the clip is not reset then it wont catch the chain mechanism again to open or close the door. If you havent already reset the pull cord clip then that would be my guess. Try closing the garage door reset the clip with the rope attached, push it up til it clicks. and hit the garage door opener button. the rope and clip should move along the track until it hits the arm bracket where the garage door attaches to the chain mechanism.
If that does not do the trick then the clip has some screws on either side of the plastic casing and may need to be loosened and readjusted to match up with the garage door arm bracket and then locked back into place. That should do the trick if all esle fails, you may have to call the door company to come and correct the problem. Hope it works out!
May 28, 2012 | Home Security
I had to manually close my craftsman garage door and now it won't respond via the remote or the wall button. Chains move but not engaging with door.
Look for a red handle with a rope attached along the bar from the main unit to the door. Pull this handle and release until it engages the track again.
Jul 07, 2011 | Craftsman Sears Liftmaster Garage Door...
Garage door opener wont switch from manual to electric again
I think what you mean is you pulled the rope to open and close the door manually and now you can't get the two halves of the trolley to reconnect.
If so, pull straight down on the rope and release. Then run the door so the two halves of the trolley connect. You may have to do that last step manually. If this isn't your problem post back.
Jan 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener 1/2 hp about 6 years old. Will not respond to remotes to open and close. Light flashes on opener when remote is pressed but no door action.
Door sensors are not working. Check if lights are on both sides.
Might be misaligned or one is bad.
Door will close if you hold in the garge close button until it's all the way down.
And it will open on it's own.
You can get these off ebay.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Reset Craftsman keyless entry pad.
What you are asking for is not possible. You need to call a garage door repair technician. They will drill a hole through the door and using a special tool can pull the rope to release the door.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close
Check if there is a shadow being cast onto one of the sensors as the door closes. We've had the rope for manually closing the door cast a shadow in full sun and trigger the "something crossed the beam" safety reverse. (Our temporary solution was to cast a shadow that remained constant from outside the door.)
Similarly check if there are any weeds or grass that are being blown or bent into the opening as the door closes. If there are plants in or near the doorway, trim them or use an herbicide to kill them and then trim the top growth after the plant dies.
Mar 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage opener/ brand garage master 1/3 HP
trolley is not attatced to the chain, grab that red rope that is hanging down and give it a ****. run the door up until it re-locks onto they trolley
Mar 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
382 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
