Question about Bissell 3576 CleanView II Bagless Upright Vacuum
How do you change belt. I have cover off, but can't get brush off
How do you change belt? I have cover off, but can't get brush off?
  • Anonymous Mar 26, 2014
    how do you take the plastic cover off the power brush to change the belt
    Problem Solver:
  • 6 Answers
How to change vacuum belt on bissell 6583-x
I am not familiar with this model but the first step would be to
remove the brush bar cover...this may be attached by screws
or numbered tabs which are released in sequence starting
with #1. With the cover off pull the brush bar out and slip the
belt off the pulley. Be sure to buy the correct belt and line up
the groove on the brush bar with the motor pulley...put the belt on
the pulley and stretch the brush bar forward and insert into the
slots on the sides. I hope all this applies to your vacuum.
Regards,
Dennis
Aug 10, 2014 | Bissell Vacuums
How to change the belt on a Eureka powerline limited edition vacuum cleaner.
The belt is directly connected to the brush roller. Remove the brush roller cover. Pull out the brush roller. Remove all carpet strings. Change the belt.
Jun 11, 2011 | Vacuums
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
How do I change the belt on a Bissell Powerforce model 3522-1?
this is how you do it Lower handle and place vacuum on floor so you can see bottom of power head. Examine the power head to remember what it should look like when finished. Unscrew the four screws (Phillips screwdriver). Lift off cover. Lift out brush. Remove belt from brush and motor shaft. Place new belt around motor shaft, then around brush just prior to reinserting brush. Make sure the belt is placed correctly. Reinsert brush in slots. Rotate manually toward motor a few time to center the belt. Replace cover and screws. Tighten securely. Check cover to make sure it's properly secured.
Feb 16, 2011 | Bissell 3522 PowerForce Bagged Upright...
How to change the belt on an upright silencio
remove the 2 screws from the bottom...remove bottom cover.....pull the rotary brush straight down and out....put new belt in the groove on the brush then reinstall brush and put the belt around the metal rod thats inline with the groove on the rotary brush...put cover back on and put the 2 screews back in...thanks and have a great night
Jan 03, 2010 | Vacuums
I have a Eureka Altima and not sure how to change the belt?
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
new belt around motor shaft and
brush roll
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Bravo! 7.0 vaccum cleaner, how do I change the belt
Turn the vac over so the brush is facing up.. There is a cover plate that surrounds the brush.. Take the screws out and remove the cover plate.. Pull up on the side of the brush that the belt is on.. Replace the belt.. The belt goes around the metal shaft and the brush.. Push the brush back in place.. It might be a bit tough going in because the belt causes some tension.. Put the cover plate and screws back in..
Good luck ! Please don’t forget to rate well ;o)
Aug 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Change belt on model 6850 bissell
Turn your vacuum over and remove 6 screws holding down the cover plate which has the roller brush under it. Remove cover plate and pull up on brush. Belt will come off with the brush. Put back together in reverse order with new belt.
Jun 29, 2009 | Vacuums
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
Bissell 3576 CleanView II Bagless Upright Vacuum Logo
160 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
