Nokia N73 Cellular Phone Logo
Posted on May 30, 2009
N 73 problem connecting with PC
When i try to connect my mobile with PC it prompts Memory card used by another application and connection fails
Please help
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
40
Points
Your memory card would be used by message settings would be on memory card please make the setting back to phone back to phone memory and is done .for doing this go to message open go to option go to settings , open it go to memory in use , change the settings to phone memory and done .if not then install an Antivirus kaspersky in phone memory and scan your phone .do say thanks When done.
How to transfer applications installed in my device to my media card?
  1. Connect your device to your computer
  2. Run the installation program from your computer. The installation program will prompt you to install the software application to your device using ActiveSync or Windows Mobile Device Center.
  3. Select whether to install the software to the device memory or to your memory card
When i'm connecting with the USB cable,it is saying memory card is in use by another application,and thus not connecting.........why is it so?plzzzzz sort out this problem
Hi
Please make sure you are not using any application and that insall in Memory card, Check any start up application is running, close that all application and try again. otherwise restart your mobile.
May 20, 2011 • Nokia 7210
My Nokia 6303 Mobile phone Memory card has been corrupted. I am not able to format through format tool. Please give me a solution.
if your memory card has been corrupted say with a virus, it is best to clean your memory card with a good antivirus. You can try to retrieve your files by downloading an application on the internet for free. Or an option is insert your memory card to a card reader, then connect the card reader to your laptop or desktop. Then open the command prompt. On the command prompt window type: chkdsk (drive that reads the card reader):/r
So it will look like this c:\user chkdsk f:/r then wait until it is 100% repaired then exit the command prompt then check your memory card and the files inside it.
For a detailed instruction try my link: http://www.fixya.com/support/r9041230-recover_shortcut_files_from_flash_drive
Apr 25, 2011 • Cell Phones
1helpful
My memory card is not being connected to pc using memory card reader???? my phone is nokia N 72... my phone is not working so basically i want to know how should i get the data from my memory card..
Use Nokia PC Suite, not only get data from your phone memory card, you can also install application and games or back up your contacts by this software.
- First download the software from here :
http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
- Install the software
- Open PC Suite and click connect any device
- Connect your phone via USB cable or bluetooth
- if its connected, you'll see your phone folder in Windows Explorer
- Copy your data from or to your phone/PC
If you feel this answer helpful RATE please. Thanks for using Fixya
3answers
I want to transfer some songs from comtputer to my mobile i hav joined the cable but it isnt showing corbys sign in the computer
Make sure that your mobile is having memory card inside it and is working fine.
Install the s/w came in a cd with your mobile phone.
Just connect your mobile to cable and them to computer. If anything is prompted on the mobile screen, select file transfer/ storage / mass storage mode ( may vary and if applicable).
you should be getting some extra drives in My computer, just like c:, etc using which you can access the files present in your mobile phone and can transfer the files to your mobile.
I hope this is helpful to you. Please rate
2helpful
2answers
Web camera for my desktop - nokia 5800
You can try using the smart cam software.Please check out the below link for more details:
http://nokia5800downloads.blogspot.com/2009/05/make-your-nokia-5800-act-as-webcam-with.html
Thank you for using fixya.
I was given a blackberry pearl 8100 and am trying to import my pictures from my device. i was able to from my media card, but not from the device. how can i get these pics off my phone and onto my...
Most of the mobiles will prompt the user to select the mode of connection when connected to computer such as "Mass storage mode/data transfer mode" and "PC suite/modem mode". If you select the "Mass storage mode/data transfer mode", then only your mobile phone's memory card is connected to your system just like pen drive. so only the pictures present in momory card can be accessed. For transfering pictures from phone memory, try the following methods,
1. Go to your file manager in mobile phone, move the pictures from your phone memory to memory card.
2. Install proper PC suite for your mobile, connect to system in phone mode/modem mode/pc suite mode. Then using the PC suite file manager in your system, oyu can access files stored on to phone memory as well as memory card.
3. Connect a bluetooth dongle to your system, establish a bluetooth connection to your mobile. Threw bluetooth file manager from your system, you can browse the phone memory of your phone.
I hope any of the above tips may solve your problem.
While transferring mp3 it shows an error
basically nokia mode is meant only for those if u want to use ur for for internet nad short term applications..........for storage purposes data storage mode is used
2helpful
I want to Use my cell as n my webcam wid my pc, m using nokia 5800 exp music, so help me how can I ?
You can use an application that make your mobile’s camera act as webcam. Here is an application "SmartCam" for Nokia 5800 XpressMusic. Now you can use your mobile as a webcam for your PC.
There are two ways (Wi-Fi and Bluetooth) to connect to pc.
You can download the files from here. Simply unzip the files on your pc. There is one .exe file and one .sis file. Run the .exe file on your pc and then run .sis file on your mobile.
Bluetooth:
Connect your mobile from pc using Bluetooth. Make sure your Bluetooth is on. Just do the pairing of your mobile and pc and start using your mobile as webcam.
Wi-Fi:
You can initiate the Wi-Fi connection from pc in case you don't have Bluetooth on your pc. Open the installed Smartcam application on your pc and then go to File -> Settings -> Connection -> TCP/IP (Wifi) and make sure the settings for Port is Port:9361
Now start the SmartCam application on your mobile phone and go to Options -> Connect -> TCP/IP (Wi-Fi). It will prompt for Server Name. Fill the IP address of your pc (Use ipconfig command on command prompt to know your IP address). Now the application will prompt you to connect to the Internet, choose Wi-Fi to connect to the internet.
Hope this helps.
Also updating your phone’s software may be useful for that. To update your mobile :
1.Backup your personel data to you memory or PC in case not to lost it and restore your personel data to your phone after update completed.
2.After using the Nokia Software Updater, many settings (including your security code) are reset to default to ensure correct operation. Enter the default security code, of 12345. You can then change your security code later.
3.To read the detailed information before updating click here:
4.To start to update your mobile from the Nokia Webpage click here:
Good luck.
Transmission Failed
first check your mobile for viruses some viruses in ur flash memory (memory card) does not allow u to explore your flash memory so sacn it with a good updated antivirus system when you connect your mobile to ur PC about some tools i can define some great sites http://dwalx.motofan.ru/links.php u can get skin manager and the best is "motomidman" . when u connect ur mobile to pc and start motomidman it shows files and applicationbs like games that are on ur mobile and helps u to rename or delet or move ur applications from memory card to phone memory etc LOGIN TO THE SITE(MAKE UR USER OWN USER ID) http://developer.motorola.com/docstools/othertools/Media_Manager1.8/MM18win.zip/?login=1 to get more good tools
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
