Question about Refrigerators
Freezer works fridge doesn't both worked yesterday today fridge wont
Maytag MSD2758DR side by side slid the fridge to rearrange kitchen and now the freezer works but the fridge doesn't
    President:
  • 1,136 Answers
Hi, Check and see if the condenser fan motor down by the compressor is running. Sometimes when they get moved, something will get into the blade and stop fan.
That will overheat the compressor and cause it to shut off on safety. If that fan is running, check the fan inside freezer and look to see if frost is building up on inside rear freezer wall.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on May 30, 2009
Removing doors from a Maytag fridge
first try to open both doors and slid it threw the door. slide it threw like a c if you know what im talking about. i sold ge and westing house at the local goodyear tire store foe 19 + years. it worked for me.
Nov 03, 2009 | Maytag MTB2195AE Top Freezer Refrigerator
Freezer not freezing at all
the gas maybe gone,check with you're supplier
Sep 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
MY MAYTAG FRIDGE SERIAL #MSD2758DR
the refrigerator needs serviced bye a refrigerant expert there's a valve in that closed system needing replaced and the refrigerant may need recharged . but beyond that i would inspect the area aroiund the compressor and bloswer to make sure nothings blocking it unplug the fridge and let it set for a day then plug it back in .Did the fridge get layed on it's side ? if so it should be allowed to set for at least 24 hours
Jun 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
Bottom of Maytag Freezer Ices Up
We had the same problem; soon your other side of the fridge will start to not cool as well. A circuit board had to be replaced per the Sears repair guy. Cost was about $270 but our icemaker doesn't work so well still. The ice cubes are hollow and it doesn't churn as well.
Aug 16, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
251 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
