It won't spin when clothes are in it....but it does spin when empty
My machine won't spin when clothes are in it .......but when it's empty ........it spins fine!
  • 10,865 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 30, 2009
  • Joe Hogan May 30, 2009
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
Won't spin with clothes in. Will spin when empty
Check the drive belt and tension arm spring and make sure it has not dislocated itself. The drive belt is the most likely problem if the motor is running during the spin cycle.
!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 12, 2012 | Washing Machines
Washer won't shift into spin
with a lot of the machines now they wont go into spin mode if the drum is not balanced properly, like say you had a load of towels in their, well it wont spin as its to unstable to spin without wobbling around so it simply stops at the spin cycle and does nothing, you can try this by turning it on with no clothes in and see if it will go into the spin cycle with no clothes in, if it does then chances are its not weighing the clothes properly and would end up costing a fortune to put right as it sounds like you spent a lot of money on parts all ready, so give i a try with no clothes in and see if it will spin, have you tried turning the drum by hand when its switched off to check for any grinding noises or jerking when you try to turn it by hand, im not sure how the balance sensor works or even where it is as its a new feature in the last few years but people are now starting to have problems with this feature and it stops the machine from spinning leaving the clothes soaking yet, so give it a try empty and see what happens
May 16, 2012 | Whirlpool Washing Machines
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Daewoo DWCLD1013 washer & dryer The cycle keeps getting stuck on spin at around 10minutes, at which time it keeps going round and round with no actual fast spinning, until it stops about 20 minutes...
The cycle that the machine is stuck in is in fact the empty cycle, just before the spin kicks in. It is staying there because it has a problem evacuating all the water. The machine won't go into spin until all the water is gone and after a set time ( 20 minutes is unusually long, most machines stop after about 10,, but I'm not familiar with Daewoo), the attempt to empty is aborted and the machine stops.
Your problem therefore is either:
The filter for the empty pump is clogged with debris (far and away the most likely) you will need to locate and clean the filter
The EXIT to the drain is blocked, check the empty pipe is not blocked
The empty pump has failed (you would usually expect to hear the pump rumming, but it may not be a noise that you are familiar with).
First and second items are easy to fix, the 3rd is a pump replacement, which isn't that hard, but depends on your level of DIY skill
Jun 23, 2011 | Washing Machines
Will not empty water
sounds like ur pump is getting weak and going out it will have to be replaced
Feb 25, 2010 | Hotpoint Aquarius WF210 Front Load Washer
How can I get my washing machine to spin and empty with bad timer
Emptying the tub is easy, just lower the drain hose into a bucket on the floor, or into a floor drain. If the timer can be operated manually, turn it to spin, then drain after spinning a while. If this is an electronic timer, you will need to remove the clothes and take to a laundromat or a friend's house to spin the water out.
Dec 03, 2009 | Washing Machines
Will not spin with load of wet clothes but will spin when empty
clutch not engaging properly perhaps the belt is streched. Timing module not grounded properly, faulty module, motor circuit bad (brushes worn)
Nov 22, 2009 | Washing Machines
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
