Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Another Lockout problem
I have an instalation of XP on a HD that wont boot up normally.
Following advice I have tried to boot from the CD but I get to a prompt asking for the administrator password.
None of the passwords that I have ever used, or any of their variations, will work so I cannot run the repair mode. I have another installation on another drive so I can see the documents and files that I want to save but they are password protected and so I cannot move the in the usual way.
Any ideas about how I can either:
Reveal or bypass the password to allow me to run a repair?
or
Unlock the files so that I can back them up and format the drive?
  • astrocan Oct 23, 2007
    I will try your suggestion for booting in safe mode but I have not had any success with that so far. You suggest putting the HD in another PC with XP installed but I already have XP on another drive on the current PC, Is that the same?
    Thanks, I have got ownership of the documents and files that I wanted but I would still be interested in getting the original installation going again so that I can archive my emails and transfer them to the new installation. Failing that where does Thunderbird file emails so that I can import them into the new installation.
    Scholar:
  • 90 Answers
You need to take that hard drive that you wish to get info off of, stick it into another pc with XP and boot into safe mode. During the power on, before the XP logo, us the F8 key (tap a few times) to get the boot menu. Choose safe mode.
In safe mode, if you encounter a folder that says access denied when you try to open it, simply right click on it and choose properties. You will then see a tab for security. Under this tab, you can chage the permissions for that folder, by adding the correct user and granted permissions to view/read/write. This will allow you to gain access and be able to copy off what you need. You cant make these permissions change sin safe mode that I am aware of.
Posted on Oct 23, 2007
  • Chuck Gluth
    Chuck Gluth Oct 23, 2007
    I meant, you cant make the permission changes in normal mode. Once your in safe mode and you can access the security tab of a given folder with the right click, properties option, you should be able too easily figure out how to add a user and grant permission. If you have further questions, feel free to ask.
  • Chuck Gluth
    hmmm, never used thunderbird for emails. so im not really familiar with it... if it were Outlook I could tell you. Don't know if this will help, but, with outlook, emails are stored in a type of database file. Each box in outlook has its own file. Such as INBOX and DRAFTS, etc.. When backing up the files, you can re-import them into outlook on another pc if you want. But you have to use the import function in Outlook, then point it to where these files are that you copied. As far as the address book, in outlook, theres a WAB file on your hard drive that has that info in it, I would assume though that Thunderbird has its own book.
    So with that in mind, you should be able to find somewhere on your drive, the files that Thunderbird uses to store your emails it downloads. Simply copy the folder over to the other drive. Install TBird on the new drive and then see if it has an import function to import old email, and point it to the folder you copied over. Hope that makes sense... should be similar, then again, I've never used TBird.
    The tbird files may be located in Documents and Settings/Username/Application Data/Thunderbird or something similar, have a look around in that profiles docs and settings folder. You may also have to have your folder options set to show hidden files and system files. Find that under Tools/Folder Options in your explorer.
    Now what was the issue with booting the old drive? Just a password problem, couldnt get onto the windows desktop?
Hi Everyone , After trying to solve the start up
After this reply you will still not be able to start normally.
The boot to lan is trying to start off an image stored on a server, you normally only see this at a business.
Boot to CD is looking for a bootable CD like the disk used to install Windows.
Boot to hard drive is normal but from your post it appears that it cannot communicate with your hard drive. Normally, when you have hard drives issues, the file is corrupt and at this point the computer complains but is sounds like it just freezes which suggests to me that the controller is gone.
In short, in order to get this working you will probably have to buy a new hard drive and reinstall Windows from CD. Since the version of Windows you have is XP (if you have the disk) and support for it ended almost 3 years ago, you are probably better off just getting a new laptop. https://www.microsoft.com/en-us/windowsforbusiness/end-of-xp-support
Mar 04, 2017 | HP PAVILION DV4000 AND V4000 SERIES...
Windows\system32\hal.dll. corrupt
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP
Method 2
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed:Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 3
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Jan 19, 2013 | HP OmniBook XE3 Notebook
My Acer 6930 laptop won't turn on all the way...
Hi there please try the steps below mentioned.
Please restart your laptop when its booting press F8 key .
56ee508.jpg You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. NO w select the OS & enter again. Laptop restart automatically. After that If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Mar 19, 2010 | Computers & Internet
How can i install a 320GB sata II hd using Win XP without that jurassic 1.44 damned Disk ?
You can slipstream the drivers from the floppy into an ISO image of the Windows XP installation CD using a program like nLite.
You can then burn the slipstream ISO image into a CD & use it to boot & install Windows XP without the need to use the floppy disk.
You can download nLite at the following link:
http://www.nliteos.com/download.html
After downloading the installer, install the program & start using it.
The following link describes how to use nLite to slipstraem the SATA drivers into the Windows XP installation CD.
I tried this myself, & it worked without problems. I now no longer need to use the floppy drive when installing Windows XP on my system.
Jul 19, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
Need floppy to boot in XP PRO on HD
Hi, if you can boot using xp cd then instead of going into recovery console you can elect to install xp. The cd will search for existing installations and offer to repair for you. If you are able to get this option it will not delete your programs or personal stuff. You will need your xp code and you may need to reactivate windows when finished. If it doesn't offer repair then f3 to exit so you don't overwrite your personal stuff.
Jun 07, 2009 | Microsoft Windows XP Professional
Hard Drive Prevents any other windows device from loading
Hi, Mark Here.
Yes the setup on the xp install puts drivers into memory, but being an older version of windows B4 sta was out it does not have drivers to support it.
You could go to Microsoft & search for a new version of setup install drivers that includes sta, & download to thumb.
Really typical Windows Failure (driver not available freeze up or blue screen).
Mar 22, 2009 | Computers & Internet
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Can't install xp - freezes
You need a CD/DVD USB drive.
Ask for one or use a HD 3,5" USB drive, open de HD USB disconect the HD and conect a CD drive, it will work like a CD USB drive.
Jan 10, 2008 | ViewSonic Tablet PC V1100
Can't install XP
It could be bad RAM, but it could also be drive error.
Try running chckdsk.exe
If the drive is ok, try copying the win xp cd to the HD and try to install from the HD
First, you need to copy your Windows XP Setup CD contents to your harddrive. I recommend saving the xp install files/folders to a separate partition than where you're going to install xp to (ie. have setup files at d:\winxp\ and then install xp to c:\ drive)
restart your computer with the win 98 boot disk
at the command prompt change to the drive with the xp files
ie. cd d:\winxp\i386\
type winnt to start installing
install as usual
Dec 28, 2007 | ViewSonic Tablet PC V1100
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
