Question about Minolta EP1030/1030F CS/PRO Copier
Minolta machine whin i take photocopy the photocopy is come only half the paper is not coming complet. this is my problem thanks..
  • 320 Answers
Are you missing the half from right to left? or from left to right? typically if you are missing print from right to left it is a problem with the high voltage power supply. have you tried scanning to file on you computeer? does it have the whole picture? i would need some of these answers to further help
Posted on May 31, 2009
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
Minolta CS/Pro 1031 Refuse to work and display PC
Check your paper supply in the paper tray. PC means the machine thinks it has no paper or the paper did not feed. If making sure the paper is good and loaded properly does not solve the problem then pull out the tray completely and clean the rubber feed rollers inside of the port where the tray came out off. They should be about half way to the back and over to the right side. Most common cause of this problem is dirty/dusty feed rollers that are not pulling the paper up into the machine. Just wipe them down with glass cleaner of even a cloth dampened with water.
Good Luck and Thank You for using Fixya.
Jul 14, 2010 | Minolta EP1031/1031F CS/PRO Copier
Error message
load more papers in your printer or copier to start it again.If it doesn't,ask again
Apr 14, 2010 | Office Equipment & Supplies
Minolta photocopier di350 b&w what is code
Image unit code. new image unit required first try powering machine on then off. Does operator screen say Image unit needs rreplacing
Jun 04, 2009 | Minolta Office Equipment & Supplies
Jammed Photocopier
you need to remove the drum unit out of the machine,and take cotton rag use achohol ..rotate the drum clock wise until you see the label that stuck on it..
good lock
Feb 28, 2009 | Lanier Office Equipment & Supplies
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
The copied paper is half soiled with fuser oil.
Pull out fuser unit and remove the top. ( let machine cool down, VERY HOT!!) does the fuser web need replacing ( looks like a white paper towel roll) it has fuse oil on it. is it overflowing?? try cleaning, do not spill on floor it is very slippery and hard to clean up.
Jan 22, 2009 | Canon CLC 1000 Color Copier
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Jammed Photocopier
I would suggest that a label came to be attached to the photorector drum. Unless you can remove this label the problem will continue
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
59 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
