Question about Philips HTS3400/37B System
Philips HTS3400 AUX input not working
Came home one day after work, turned on my Philips HTS 3400 which is hooked up to my XBOX 360 through the AUX inputs, only to find that the sound is low and static-y and nonexistent in some speakers. I switched my AV wires to the TV input, and no sound comes out at all. I tried playing a CD and the CD played fine, so I'm guessing the problem is with the inputs only. Any help is much appreciated.
welcomejee
  • 10594 Answers
SOURCE: Lost installation guide for Magnavox MRD 510 Home Theater System
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper in your case.
Posted on Sep 11, 2008
SOURCE: Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
Posted on Oct 06, 2008
SOURCE: philips hts 6510 no disk prompt does not play dvd
has worked fine but now doesn't play any dvd. comes up with 'no disk' on tv monitor. please help
Posted on Oct 12, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Power on the system
Eject the disk tray
Press Stop for around 2-3 seconds
Type in 7,3,4,4,6,6,0
You should get a message saying your player is now Region 0.
Posted on Oct 20, 2008
Xtremeroofin
  • 67 Answers
SOURCE: I have a Philips DVD
Audio input (right&left) Should be red&green
Posted on Dec 23, 2008
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Tip
Stuck in Progressive Scan? Can hear movie but Can't see Video?
Here's the scenario:
All cables hooked up correctly.
System is stuck in Progressive scan (P-SCAN on display viewer)
SITUATION:  You can hear the movie playing, and you are certain all connections are correct.  Your Television may not support Progressive Scan Video so all you hear is the Audio Track.  Here's what to do.
SOLUTION:
Step 1: Remove DVD from player.
Step 2: Unplug from power source for 20-30 seconds, plug back into outlet.
Step 3: You need to press two buttons at the exact same time.
Step 3a: Prepare to press #1 on your HTS remote
Step 3b: Prepare to press OPEN/CLOSE button on your HTS.
Step 4: Press both OPEN/CLOSE button and #1 on your remote at the same time and HOLD until P-SCAN on your HTS display turns off. Should take no more then 20 seconds max.
Step 5: Repeat all if human error occured and no improvement. Or call 1-888-PHILIPS for HTS tech support
Enjoy!
NOTE: This solution was given to me by Philips Tech Support Division when I encountered same issue.
on Sep 11, 2007 | Philips HTS3400/37 System
Hook xbox 360 up to philips mx5100/37 home theatre
Try Putting the "prongs" (RCA connectors into the front AV socket of the Philips System.
You could hook it up at the back but that requires the xbox to SCART lead. (Scart is the 2 pin socket on the back (2) that are about 5cm long
If you aren't fussy then just plug it into the front and select the front av input and you are away!
Happy Gaming!
Jan 17, 2010 | Philips Audio Players & Recorders
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Television surround sound problem
well u have to use tv rca out to a input on this system ok then select input 1 aux in ect on sound system ok
Feb 02, 2008 | Pioneer HTS-GS1 Theater System
Reads NO DISC Philips HTS3400 Home system
Run a dvd cleaner through system, and try again. If that fails, unplug the HTS from the wall outlet for 10-15 seconds, and replug it. If that fails, it will need to be repaired.
-Tha Mp3 Doctor
Jan 27, 2008 | Philips HTS3400/37B System
Philips Home theater system
Just run the yellow cord that came supplied with the HTS from the CVBS plug in the back of the HTS to any available yellow video input on your TV, then you want to change your TV's video/source/input/channel (the wording varies by tv manufacturer) to Video 1/AV 1/Aux 1, or whatever your television is calling the yellow input that you plugged into.
Also, Philips number is 1-888-PHILIPS
-Tha Mp3 Doctor
Jan 12, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
WIRE ELIMNATION
For the TV:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
For the Xbox, try hooking a red/white audio cable from the Xbox into the Audio IN/AUX on the back of the HTS, and then switching the source on the home theater to AUX.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 06, 2008 | Philips HTS-6500/37 System
Constant beepingg, does not turn on
Have you performed a "hard start". This is done by totally unplugging the unit from the wall and waiting for 15 seconds. See if that helps...accordianman
Jan 01, 2008 | Philips HTS3400/37B System
Philips HTS3400/37B System Logo
211 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
