Question about Gateway FPD1975W 19" LCD Monitor
RGB No Signal Message
Everytime i turn my monitor on a box comes up and says No Signal and below that says RGB with a red green and blue background and after it says that the blue light turns orange i have tried unplugging and plugging in the vga cord and it still wont work what do i do im getting really frustrated and am about to throw my computer out the window
  • 748 Answers
First you need to check the cable at both ends, inside and out. Make sure it is plugged in, to the proper connector and that there aren't any bents pins. Now put this monitor on another computer, a laptop will do. Does it come on now? If so then your video card in your machine is bad. If still bad then the monitor has lost it's signal input. This will have to be repaired by a pro. I repair these all the time and it's not as expensive as you might think.
Posted on May 30, 2009
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
What would be the best thing to do if my computer goes No signal and RGB with a red green and blue background and screen turns off by it self
go to safe mode and try to reduce the resolution to like 800x600 and see if that would fix it. if the monitor is good you should be able to see everything on the screen. if so, then you have to find out what's the max resolution the monitor will take and adjust to that setting.
good luck!!
Sep 01, 2011 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD2275W LCD monitor lost "Red" signal of RGB display
Not really, first check your connections, normally when you loose red a pin broke off the VGA connector.
If the panel died then its probably not worth while. The red panel is however, under the most stress.
Jul 09, 2010 | Gateway FPD2275W LCD Monitor
I am getting a no signal message on my monitor
Don't worry just reset of your bios default settings and check it now :)
May 14, 2010 | E-Machines eMachines Desktop PC
check the cable connections or replace the vga cable
Mar 25, 2010 | E-Machines eMachines Desktop PC
I moved my tv and now I am getting message No RGB signal, power will be turned off
If you had something plugged into your component jacks that's the red, green, and blue That's what RGB stands for and they are usually accompanied with another red and white set of plug ins that is the audio. Sometimes people use them for hooking up their DVD players,Cable boxes, or Satellite receivers. When you moved the TV it might have come lose. If not you can go to input or input select on your TV and change the input to what you are using Composite,HDMI,etc.I hope I helped you.
Mar 03, 2010 | Vizio L32 32 in. LCD HDTV
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
In visual basic how will we change the backcolor of the form randomly when we click the command button?
Paste this code on you button. This generates a random color.
Red = Int(Rnd * 255)
Green = Int(Rnd * 255)
Blue = Int(Rnd * 255)
Form1.BackColor = RGB(Red, Green, Blue)
Oct 06, 2008 | Computers & Internet
Colors reversed on samsung 2220vm
You got a loose connection on your VGA 15pin Socket. everytime the color signal got loose there is a invert video.or missing color signal.Possible cause in which terminals in a bad contacts with wires. preparably the RGB color signal, replace only the 15 pin male socket... which is pin 1 for Red pin 2 for Green pin 3 for Blue..
others pins just trace the signal.. don't worry its color coded.
Mar 03, 2008 | Computers & Internet
Gateway FPD1975W 19" LCD Monitor Logo
2,777 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
