Question about Sony VAIO VGN-A170P Notebook
Laptop Screen My VGN A170P screen has a burned out back lite but I can see it try to light up when I turn it on. So I hooked up a external monitor which worked for a good while but now the monitor will come on and after about a minute the Vaio will reboot itself time and time again. I may need to do the fn -F4 only because I heard what it may be, but I want to know of any other options. A new screen now would not make me happy. Thank you micheal (sage)
    Problem Solver:
  • 15 Answers
My Sony Vaio VGN NW225F laptop won't start up.
First thinkg I'd do is to connect an external monitor to the laptop to see if you can get an image, any image, during booting. If you can't see anything, either using the laptop's screen or external monitor, then you have a hardware failure in the laptop that's probably beyond the abilities of a novice to repair. Get somebody who knows about how to clear the CMOS of the laptop.
Nov 08, 2017 | Sony Computers & Internet
I have a Sony VGN-CR220E. It would turn on but all I see is a black screen. The green light on the bottom lights up but all the rest won't light up anymore especially the 3rd light that would blink,...
One thing to try is if you can, connect an external monitor to the computer. Turn it off and then back on with the external monitor on. If video on the external monitor then the problem is with the laptop monitor most likely the FL inverter or the lcd itself. If no external video, it is most likely a motherboard problem.
Jun 30, 2011 | Sony VAIO VGN-CR220E/P Notebook
I have a light pink Sony Vaio VGN-CR510E and i've had it for a little over two years now. The screen has gone grey/white and will only return to the natural screen when the tops of the screen are squeezed,...
I wouldnt say beyond repair, if you were able to compress it and the screen would appear normal there is a connection problem, your monitor has small connections making it work one happens to be an inverter. It could be that the connection is loose, the bad thing about that is if its loose there is a chance it could cause a short which in return you will need an inverter or whole monitor.
1. try hooking it up to an external monitor, you need a vga or dvi cable and try hooking up to a projector or another monitor, if that doesnt work its your video card. unfortunately either fix is somewhat expensive. Good luck and please vote thank you.
if you have have hooked up an external monitor before here are some instructions
1. make sure the power is off
2. plug the vga cord to your laptop and to the external monitor, 15 pins normally blue or back has 15 little holes ive seen some that are pink.
3. turn both on
4. you may have to hit a function key thats the fn button plus (on mine is f4 small rectangle with a line on each side of it .
5. if the external monitor works then your monitor or the cables to your monitor are bad
6. if the external monitor doesnt work its your video card and you will need a new motherboard if the card is integrated.
Feb 18, 2011 | Sony VAIO VGN-CR510E/L Laptop
I have a Sony VGN-CR220E. The backlight works and the screen gets bright but the video display has nothing but lines and some color but not in any reconizable paterns. Any advice?
The LCD screen is bad, or the video cable from the motherboard to the display is loose and needs to be reseated back in place. But before we call it ! hook an external monitor to the video output at the back of the laptop, If the monitor is good it is the laptop screen, If both show the same problem it is the video graphics card that is apart of the motherboard.
Jan 25, 2011 | Sony VGN-CR220E/L Notebook
Turn on get blank screen VGN-FJ270
Hook an external monitor to the video output on the back of the laptop, If okay! problem is the computer display screen, caused by a bad inverter board, or the back light behind the LCD screen. If both displays show the same issue, then it is the video graphics card that is part of the motherboard. I suggest a technician to take it further with an estimate in mind.
Jan 21, 2011 | Computers & Internet
My screen is not working on laptop . I hooked it tp another moniter and I get start up and works fine. I thinks its could be 1)wire from mother board to screen. 2)Inveter gone bad. 3)Back light . Any ideas...
you can try to change wire but extremely hard to do so. most like your monitor has blown and to fix this problem you have to get the exactly same monitor for the laptop your better off hooking it up to and external monitor.
Nov 19, 2009 | Gateway MX6445 Notebook
My lenovo Y510 ideapad turns on but the screen remains black. All of the buttons light up, but the screen stays like it is in sleep mode. I have tried rebooting, removing the battery but nothing seems to...
The next tim eit is turned on, try shiniing a bright flashlight directly on the screen.
If you can see anything there then the backlight has burned out on the screen, and will need to be replaced.
If you cant see anything, try hooking up an external monitor to the laptop, if you have a desktop the monitor for it will work for the test..
If the external monitor you hook up will work, then you will have to replace the screen..
( or at a minimum the inverter board, or check that the cables are tight that go to the screen)
Oct 31, 2009 | Lenovo IdeaPad Y510 Notebook
Vgn-fs730
Get an old monitor CRT or LCD. Connect this to the back of your laptop to the appropriate connection. Turn on this monitor and your laptop. Now on your laptops keyboard are some blue highlighted keys called function keys. Press and hold the one marked "Fn" and then press the F7 key (on my Sony - yours may be different but the key with a small blue rectangle with LCD inside a foward slash to what looks like an oval with square sides) this is the external monitor key. If the external monitor comes on with the laptops screen information then your mercury lamp in the laptops screen has died. Then a reputable repairman can replace your screen and lamp for $200. - $300. If nothing appears on the screen then most likely the video chip in your laptop has died. Replacing this will require a new motherboard for the laptop. You should contact Sony about price and any extended warranties they may have,
Jan 13, 2009 | Sony VAIO VGN-S460 Notebook
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
Sony VAIO VGN-A170P Notebook Logo
66 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
