I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player with the Fios System?
    Brigadier General:
  • 8,619 Answers
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
1. Press and hold the STB key.
2. While holding down the STB key, press OK.
3. Release both keys. The Device Keys will blink twice.
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 30, 2009
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
Jan 22, 2018 | GE Televison & Video
Progam phillips RC144 remote for verizon fios
the remotes usually to program combos ...but you may want to try the dvd ...and vcr codes ...as well
May 22, 2010 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Using FIOS HD DRV STB with a VCR
Okay let me make sure I understand.. Looking at the back of your STB and VCR do you see an (IN) and (OUT) coxial connection?
If so, you can use the coxial connections to obtain your desired results.
I hope this solution is helpful. Please remember to rate thsi solution.
Feb 12, 2009 | Televison & Video
Can't record
id get some spliters and hook it up that way or call 888-553-1555 and up grade to a dvr where you can pause record and rewind live tv. or get the home media dvr where you can record 2 shows at one while watching a 3rd and record on the hmdvr and play that same show on up to 3 other tv's
Oct 29, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need remote codes to enter into my verizon fios remote
what kind of equipment is it? cus you can go to verizon.com go to fios tv then installation then support and click on remotes then get codes for yada yada yada/
Oct 23, 2008 | Broksonic CCVG297 9 in. TV/DVD Combo
Sanyo VHR-M291
This unit needs new rubber parts. I don't know the particulars of your model, but it has drive belts and/or an idler assembly that needs to be replaced.
Dan
Oct 01, 2008 | Sanyo VHR-H531 VCR
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
Guide plus
Are you sure this isn't coming from the tv (is it an RCA or GE?) and NOT the vcr? Either way you would access it in the Menu under Setup or Initial Setup.
Aug 05, 2008 | JVC HR-VP673 VHS VCR
Televison & Video Logo
336 people viewed this question
Top Televison & Video Experts
