Question about Brother MFC-5840CN All-In-One InkJet Printer
After lightning struck in my backyard, printer won't turn on.
Lightning strike in backyard, afterwards printer won't turn on. Power is going through, because printer seems slightly warm on sides. Can this be fixed?
  • 6,784 Answers
HI, this was an unfortunate surge that has fried the power board Assembly in this unit. it has also fried the main control. this may be a total loss unless, you are considering replacing the entire mother board and power assembly as well.
Replacing the main control board and power board will restore proper function.
Posted on May 30, 2009
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
Dead SA-HE 100
hi due to it being lightnig strike their could be that much wrong with it that you might never find the problem.
If you are going to try and repair it then your going to need a multimeter and also get hold of the schematics so you can follow them and for any part numbers you might need.
The chances are its going to be several blown resistors because the lightning strike causing power surge so i would start looking around the board where the power lead goes into the board this would be a good place to start testing
Feb 13, 2008 | Panasonic SA-HE100 Receiver
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
How do I fix a 50 Plasma TV that seems was struck by lightning
Your probably have power supply damage, but lightning strikes can do major damage in all circuits.
Aug 07, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
Sony Bravia KDl-55EX720 Struck by lightning.Red light shines.Nothing else works.
Claim on your insurance. lightning strikes reach voltages higher than a PCB (printed Circuit Board ) can handle. most of the chips inside will probably be bits of burnt glass now.
Apr 04, 2013 | Sony Computers & Internet
Samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
Mar 18, 2012 | Samsung Televison & Video
Since lightning struck the house the CM1312 is dead. I looked inside and the main fuses are okay. Any suggestions?
Call your insurance company and put in a claim.
If it is under warranty call HP.
All bets are off after a lightning strike
Jun 11, 2011 | Office Equipment & Supplies
AC won't cool
you would be surprised what lightning can do if its documented on a service ticket insurance will pay. usually the tell tail signs of a lightning strike wire connections look like welding splatter. have compressor changed and both coils cleaned. Tom
Jun 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Sta-rite dura glas pool pump not getting power after lightning
You need to start checking for power from the breakers to the timer to the sw to the back of the motor. With a lightning strike it could have fried any one of these itims or all or a wire first shut your breaker to the pump off and turn back on to be sure it resets. then go down the line checking the power for 220 all the way through if your not comfortable with elect. call an expert. But where your power stops is where your problem is, and rember threr can be more than one.
Jun 09, 2009 | Water Warehouse Nsf Approved Sta - Rite...
Lightning Strike
Replace with new will need new main board (170 bucks) and modeum board, for best protection it needs a fax filter that protects power line and phone line, standard surge protecter only protects power line
Nov 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
519 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
