Question about Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
Manual start only one year old prime 3 of 5 times, will run until primed fuel is used up. HOW do I drain carbureator bowl? iow water? in carb? I am having the same problem, although my mower is 7 years old. (Model 20016, 22 inch Toro Recycler). I have changed the air filter, the oil, and even emptied the gas tank and bought fresh gas. The mower starts in one shot after priming, but then shuts off immediately. Any advice greatly appreciated.
  • Anonymous Mar 28, 2014
    I HAVE REPLACED FUEL LINES, FILTER, & CARBURATOR TO NO AVAIL.
  • 10,865 Answers
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
  • ptashner
    ptashner May 28, 2012
    Great advice Joe, thanks. I had the same problem - Toro would start and then sputter out as if the fuel supply was choked off. I used Seafoam carb cleaner bought at Advance Auto, 1 oz per gallon, and installed a new air filter. My Toro started and kept running like new. Problem fixed, grass cut.
2 Suggested Answers
SOURCE: toro recycler will start until primed gas is consumed.
I had similar problem and cleaned the spark plug and that seemed to have worked, but I think that may be a temporary fix because the engine still seems to be running unevenly. I feel that it must be a larger problem with the carb. If anyone can help this novice to adjust the carb or clean both carb and filter, or offer other solutions I would appreciate your assistance.
Posted on May 21, 2009
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
I have a Toro 20462 power mower -- about 15 years old, but until just today still running great! The spark plug is good, the gas is good, the oil is good the air filter is good. After priming, it starts...
Remove and clean the brass bolt that holds the float bowl on the carburetor. Clean out the bowl too. Use no metal objects to clean this bolt. It has 3 small holes...bottom...and on the sides near the top. Use carb/choke aerosol spray cleaner on it. IT can clog (esp. without an inline fuel filter on mower). Clean the bolt good, reinstall (not forgettting felt gasket between IT and the bowl) and your runnability problem and fuel flow problem should be solved as the bolt is also the main jet of the carburetor.
Sep 11, 2011 | Toro Power Lawn Mower
After priming starts, runs and stops
If you over fill the oil your mower will not start until you remove excess oil. This should be checked first, This is a much easier fix.
Jun 20, 2010 | Toro Garden
I have a Toro model 20007 recycler with a 6.5HP Tecumseh engine. The gas had some water so i took the carburetor and gas tank off and cleaned it and the jets. The engine will crank after priming it but...
This almost sounds like a pinhole in the primer bulb but I need to know if you did the following. Did you remove the jet and venturi tube in the bottom of the carb. and clean the BRASS orifice hole and BRASS tube holes? If you did not then It will act just like the symptoms you described. Also check to see if your float bowl nut has holes in the side of it. IF it does then make sure the hole(s) are clean. Also make sure the fuel selector is all the way ON. Adittionally if the carb to block mating gasket is torn or not secure it will also perform as you stated.
Lastly the open the fuel air mixture screw on the side of the carb about 1/8th turn and see if the performance changes.
If the problem persists ....
This is dangerous due to the risk of fire but....
If you have any carb cleaner you can give it a quick shot in the nmating areas just after you start it before it gets hot to see if it speeds up. If it does, you have a vacuum leak. It is better to use an unlit propane torch if you have one.
Thanks for using FixYa,
Kelly
P.s. If the problem does persist I will need your complete engine number to proceed in troubleshooting.
May 21, 2010 | Toro Lawn Mower With Toro Power Tools
I have toro 6.5 super/recycler that stalls out after about 5-10 minutes after it starts up then it will not start for about 30 mins. i've changed the spark plug and cleaned the filter
Dont know if this is the same problem but it may help. I've recently bought a used Toro 6.5 recycler and have cut the lawn 3 times with it. This third time it began to stall out on me. If I hit the primer button several times it would start up but then die again. I thought I'd have to pull the carb and clean it, ut after looking at a few problem listings online I realized it was probably just some trash in the needle valve. I managed to get it running again by first pushing the primer pump 3-5 times, then pulling the cord to crank it, then while holding the contact bar in place with one hand to keep it running I reached down and pumped the prime button a few times before it cut out again- after one or two tries it apparently flushed the trash out and it ran fine again. Had the same problem later and fixed it the exact same way, then went on to finish the yard.
Sep 08, 2009 | Garden
Mower wont keep running
recycler toro 6hp. 10 years old,little usage. Starts then stops, have to keep priming. Can anyone help?
Jun 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will start until primed gas is consumed.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Can't start toro mower. cleaned spark plug , new air filter . will run for 2 or 3 seconds on prime , then stalls ,will fire every time , but won't continue to run what next? 22" self propelled...
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,168 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
