Question about Black & Decker TRO910W Toaster Oven with Convection Cooking
TRO910W upper elements not heating
The two upper elements in our Black & Decker TRO910W stopped working. I removed the outer cover from the toaster oven. I checked each element for continuity. Both elements had continuity. I'm not well versed at small appliance repair. Is there anything else that I can check/test to determine why the top two elements are not working? My TRO910W top elements also stopped working. My oven is only about 6 months old and has been kept clean, dry and pampered. The manual says there's a tamper-proof screw which, if opened, will void any warranty. So, I haven't messed with the innards. Others on www.fixya.com have described the same problem. The broiler guy's problem is probably the same, too. Only the top elements work for broiling. So, I assume this is a design problem. It's Saturday, so B&D doesn't answer their phone. I'll try calling them on Monday & see what's what. I suspect the temp. selector dial is the problem. It controls the top elements, depending if broil, bake or toast is set.
3 Suggested Answers
SOURCE: Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Posted on Feb 26, 2008
SOURCE: position of part for TRO910W
take the cover off by removing 6 screws around the back and 7 on the bottom (2 of these are safety screws but can be removed by a small flathead screwdriver); once you romove the wrap-around "hull" or cover you can see the spring on the left side of the oven from the frontal view.; the door stop is sort of a L shaped piece which you insert from the inside of the opening on the frame & thru the little hole on the left side of the door; once you do this stretch the spring and attach to the hole into hole you see on the middle of the L shaped piece.
Posted on Jun 07, 2009
Where do you buy heating elements for black and decker perfect broil?
I was unable to locate the replacement heating elements for your toaster oven. These parts do not appear to be available. Probably buting a new toaster oven is your best bet.
May 08, 2014 | Black & Decker CTO4400B Toaster Oven with...
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
The upper heating element is not functioning in the Toaster and/or Broil setting. Would appreciate any guidance.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
The above website address gives a list of websites that carry oven parts. If you wanted to replace it yourself, you could buy one, or maybe they could give other suggestions.
OR, Use the following to contact the Black and Decker Company.
Parts and Accessories For parts and accessories for your Black & Decker® household appliance please click on the "to order accessories link" on the right side of the page or use the following,
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Apr 19, 2011 | Black & Decker CTO4400B Toaster Oven with...
The heating elements on top do not come on to toast or bake the topside. The bottom elements heat up just fine. How do I troubleshoot? Is it worth fixing?
The following phone number will connect you with service department of Black and Decker and maybe they can tell you if it is cost effective to repair or if you should just buy a new one.
Mar 22, 2011 | Black & Decker TRO910W Toaster Oven with...
Top element not working all wires are connected
Very possible the element on top has a break some where but maybe small enough you cant see it or could be hiden. If you have access to a multimeter put it to ohms and with it unplugged from the outlet take the wires off the element and check the element itself if the multimeter reads OL the element is bad.
Mar 08, 2010 | Black & Decker TRO651 Toast-R-Oven Toaster...
Position of part for TRO910W
May 29, 2009 | Black & Decker TRO910W Toaster Oven with...
The spring detached causing the door to stay open
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & Decker TRO910W Toaster Oven with Convection Cooking Logo
108 people viewed this question
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
