Question about Plumbing
Water won't come thru the faucet.
We have a Rohl pull-out kitchen faucet with a double check valve, water will not come thru, even with the valve removed.
  • 332 Answers
Dirt in the screen before the sprayed handle, shut off vakve clogged under sink, is this something that just happened? where is the check valve located is it in the hand held or under the sink,, if in the hand held take a needle and clean it out, or call the company and have them send out a new one
Posted on May 30, 2009
Rohl pull down faucet does not swivel but to one side
Improperly, maybe. Incorrectly, probably. Have the installer redo.
Jan 27, 2016 | Rohl Plumbing
Rohl single lever kitchen faucet sprayer is working but faucet has stopped. Cleaned out the cartridge area but water has stopped diverting back to faucet. Have used faucet for years but now having trouble...
Can you post a picture or reference the model of faucet you have, also it may be quicker to call Rohl directly as warranty may apply and they may cover cost of repair parts and send them to you at no cost. Rohl 714-557-1933
Jul 23, 2014 | Plumbing
I have a R 3830 faucet and it does not change from spray to stream, it does both as the same time. Is there a rebuild kit for this problem, or what should I do to fix.
This function relies on water pressure. Remove the sprayer from the hose and check pressure. If good flow, replace the hand sprayer. If low flow from end of hose, remove hose from underside and check pressure going into hose. You may have blockage in the hose. Hose can be replaced by calling ROHL customer service at 800.777.9762
Mar 11, 2013 | Rohl R3830-APC de Lux Pull Out Kitchen...
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
Single lever with pull out accessory sprayer. Too little flow from the main spout. The pull out sprayer has more pressure than the main spout. I suspect the diverter valve is the trouble. What is the...
The Diverters Parts is C7005. Here's the parts breakdown for your Rohl faucet. Contact Rohl and have them send you new diveter for free, the A3608 seriers came with a limited liftime warranty.
Sep 17, 2010 | Rohl A3608/11LMAPC Single Lever Country...
Sprayer leaks on my Rohl single lever faucet
The spray head will need replacing, it unscrews and the new one will fit right on
Jun 27, 2010 | Rohl A3608/11LMAPC Single Lever Country...
Water leaking from the faucet onto the countertop.
http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Plumbing Logo
120 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
