Question about RCA HD52W56 52" Rear Projection HDTV
3d tv!!! i have a 56" rca tv that my neighbor gave us. he said he turned it off and the next day turned it back on and now everything looks kinda like its in 3d when i took the front off it looks like the red bulb is dim but not off. what do you think? does the bulb need replaced?
  • RCA Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d tv!!! - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
Purchased Apple TV. TV does not have HDMI. How do we hook up to sound system?
Just use a normal stereo cable with the 3.5 jack ..take a look and see what kinda in-let has for sound in ..and use a cable ..It will take teh sound automatically or you will have to choose the port ..
If you use a VGA connection for image .this is kinda needed..For a euro-scrart will take the sound for the TV stations auto ..if you use a receiver ..The separate sound is only needed for to hook up a computer or a dvd player ..(for the last one use rca cable )
http://en.wikipedia.org/wiki/RCA_connector
U can also use this rca cable for a computer if it has such a exit for image and use a jack to rca for sound ..in case it only has a rca in-let for sound ..
Dec 28, 2011 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
TV is blurry and the red and green look as if the picture is in 3d and I need glasses. Can I fix this myself?
There is almost nothing that can be fixed by yourself if your not trained in high voltages and advanced circuitry now days. This sounds like it could be your color guns going bad or the power supply.
This set also has an issue with The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.
Jan 12, 2011 | RCA HD56W58 56" HDTV
It has colors all over kinda like if u were watching a 3d movie how do i fix this or will resetting the tv help if so how do i do it
Visit www.TvRepairKits.com. You will find a solution. You must have your model number. You are concerned about a convergence problem. I have repaired a few of these. This website will guide you to a repair. I recommend this to others with the same problem. Thanks for asking, and show me some hands of support!
Sep 20, 2010 | RCA HD56W66 56" HDTV
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
I have a problem with my 56 inch rca tv while looking at it it looks like your watching a 3D movie can you help?
Ur convergence is dead,Buy a convergence kit use what in that kit.U know how to solder right.Tries these websites for kits.Tv Repair World.com or Ebay.com.
Sep 29, 2009 | RCA HD52W59 HDTV Projection Television
Rca 56 inch, picture looks like its in 3D
Go to menu then setup if you do not see convergence in menu then FL231 is bad it is on right side of FBT flyback Transfomer on the deflection board their is 3 of them in a roll small brown rectrangler looking caps but are fuses it will be the one in the Middle if fuse is good try this with set off Press and Hold at same time vol- and ch- see if set will come on this is How to Enter service Mode.
Aug 26, 2009 | RCA R56WH76 Projection Television
Rca 7302rd5 56"hdtv tv looks like a 3d moive
•Screen looks 3D
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
The convergence box keeps going out.
this 3d effect is due to what is known as convergence.i work daily on these set in the shop. (thats a good testomony for these LOL) but the first question i ask is 1 in the customer setup do you have convergence option.. Next question is the picture bow tie looking and 3d. if you are missing the convergence option chances are it is the fl231 fuse. then you need to read the fl231 fuse under tips and tricks section of this website. Convegence is controled by three cuicit boards. if any of these need to be replace a technician may need to set or adjust the convergence back to faactory specs
Apr 18, 2009 | RCA HD56W66 56" HDTV
Out of focus
•Screen looks 3D
Mar 06, 2009 | Toshiba 56HM66 56" Projection HDTV
56 inch rca hdtv
Good Day;
The RCA TV uses a different type of Convergence Circuit then most other TV's. There is A fuse next to the FLY BACK that opens that can cause this. If not handy call an Authorized Service Center, get an estimate. Cost avg $400.00 to $650.00 depending on your location and problem.
Good Luck, big IRISH.
Sep 22, 2008 | Panasonic PT-56DLX75 56" HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
54 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
