Question about Whirlpool LER4634J Electric Dryer
Dryer wont react when hit start button
Start button works fine , door switch is working, can hear timer work when door is shut and stop when is open, but stops power from getting to any motor.
  • donaldbeebe3 May 30, 2009
    Thats the problem thank you, you really saved me on this one.
    President:
  • 1,136 Answers
HI, Sounds like Normal 0 , UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
a fuse. Try this,
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    You are welcome.
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
Our Whirlpool gas dryer, Model # LDI5701W1 stopped working in the middle of a cycle. Power supply is fine. With door closed, I can't hear the timer humming. Could it be a door switch, timer,?
it maybe but here is a website that shows how to test them, it may be a loose or broken wire, a reset button on the motor, or other things:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Kenmore 72622 Gas Dryer
The timer is running but the dryer will not come
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Oct 03, 2009 | Dryers
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Dryer not turning on .
The power routes first to the door switch.. with the door open, depress the door switch...if there's an interior light it will go off. Then attempt to start the dryer with the button depressed. If it works, then the door needs to be adjusted to shut completely, if not, I would replace the door switch.
good luck let me know how this works for you!
May 08, 2009 | Dryers
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
215 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
