Question about Sony KP-57WS510 57" Rear Projection HDTV
KP-57WS510 gone crazy
All of a sudden my remote control stopped working and the following now happens:
the TV will jump into menu mode and run thru differant screens
the TV will go into convergience mode
the TV will cycle between the inputs
It's like someone is hidding behind the couch pressing the one around I live in the woods so to speak...
  • 4,402 Answers
I had where the sun would cause symptoms and where the infred receiver has bad ground or chip has gone bad.
Posted on Jan 21, 2008
I have a Sony KP-57S510 and need to get to the service menu but dont have the remote. Is there a way around using the remote to access it?
On that model I believe you need an original Sony projection remote or one of the "magic tv remotes" that support the convergence function.
Feb 18, 2013 | Sony KP-57WS510 57" Rear Projection HDTV
I am a technicien, i 'll like to ajuste the convergence for tv sony kp-46wt500 ,but i dont have the code to go in the tv (service mode)
With set off and using the original Sony remote:
Display, 5, vol up, power
Buttons on the remote will let you cycle thru the menu to the convergence adjustment--do you know what buttons to use and what they do?
Mar 20, 2012 | Televison & Video
Sony kp-57ws510 SD Tech, soldering is no
I've used them before for replacement STK IC convergence chips. Works great! Good luck!
Nov 02, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
Jun 12, 2017 | Televison & Video
The picture is starting to degrade (KP-57WS510)
It sounds like the Convergence circuit is failing. If that is the case you have two STK-392-560's that need to be replaced on the Deflection Board. A touch up on the convergence alignment may be needed. This is accessible only in the Factory Service Mode. To be sure, you may want to get a professional to come out and evaluate it.
I hope this helps,
Aug 25, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
My screen accidentally got broken but TV was working there a way to get a replacement screen? can I buy the materials to do it myself?
Sony KP-57WS510 has 3 layers front screen and I do not know what layer is broken. Part number of all 3 screens are as follows.. count it as front, middle and rear screen layers..
4-090-881-11 SCREEN (57), CONTRAST (KP-57WS510 ONLY)
4-095-924-11 PLATE (57WL), DIFFUSION (KP-57WS510 ONLY)
4-081-950-11 PLATE (57WFV), DIFFUSION (KP-57WS510 ONLY)
Also check HERE for your TV screen.
Aug 04, 2009 | Sony KP-65WS510 65" Rear Projection...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arching
Same thing happened to me. I had to get it fixed. They said it was a "tube".
Now, my problem (7 months after getting it fixed) is that it suddenly seems a lot dimmer. I'm not 100% sure, and was wondering if there was some kind of diagnostic to run to find out for sure.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
