Question about Intel D845GVSR Motherboard
Mobo giving startup problem!
Actully the problem is there for the last 3 years, but still i do not know the cause. " when i start the system sometimes it wont start, ie. the keyboard lights get on, HDD is on, CPU fan working, but no output on Monitor(it remains off). Additionaly sometimes when i am working on system it gets off, and does not restart and goes into the above mentioned condition. then i switch off the system by pressing the power botton for 5 seconds. laterwhen i turn it on, then it may turn on or it mays not and go into above mentioned condition. And sometimes the system runs for hours even all night and there is no promblem of this type." Can someone tell me what is the problem with my system? UPS is ok, got it checked. mobo: intel d845gvsr Pentium 4, 2.0 GHz HDD: 40GB
  • prakhar_g May 31, 2009
    Vajaee- No, i am not using any graphics card.
    mrninja- Its not the Monitor or UPS...got them checked.
    got the whole system checked too, no visible problem.
    The problem is in the CPU, most probably the Mobo or it may be case of Processor overheating, how do i find out?
  • veejae May 11, 2010
    do u have any video card connected to the motherboard or u r using onboard graphics.
  • 600 Answers
You have to narrow down the issue.. is it with the pc? or monitor? if you think the cpu... is the power supply fan working? is the cpu overheating? if you think its the monitor...be sure the card is seated properly and check all cables
Posted on May 30, 2009
My computer says it can not repair automaticlly then when i click finish it shuts off
In Startup Repair please select "System Restore" and restore the system back to a couple of days before the problems started. That will fix the issues with corruption of the registry.
If that does not help, try to see if you can start in safe mode - Pressing F8 at startup will give you safe mode options.
If neither works, it's possible that it is a hardware failure of some type. most likely a MoBo failure.
If you are able to start it up in safe mode, I would grab a USB thumb drive and save what files you can.
Mar 01, 2013 | Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Windows7 does no load on start uo. Startup Repair has tried several times but still cannot determine the cause of the problem
Win7, I have to say, is a very stable OS and the cause of your problem is possibly malware/Viral or just hard drive errors.
If you can boot up within safe mode, run CHKDSK/F from the search box and reboot.
Fingers crossed it is fixed.
Feb 16, 2011 | Computers & Internet
Asus mobo flashes on startup, no video
You should unplug the power cord from the power supply, pop out the cmos battery, switch the bios reset jumper to the 2 and 3 pins, wait about a minute, put the jumper back to 1 and 2 pins, put cmos battery back in, plug in power cord to psu and turn on pc. If you have any issues with this process please refer to your owner manual for the motherboard or look one up on their website. Please let me know if this fixes your issue.
Apr 30, 2010 | ASUS M4A77TD Motherboard
Acer Computer... extremely slow response time.
try installing ccleaner. It is free software from download.com
once installed go to the tools then to startup and disable anything running in the startup. then run cleaner. If it is still running slow change the ram. There may be some kind of driver issue with your speakers. They may also be bad speakers. Who knows' but the netbooks are not going to have the best quality of sound anyways. worst case buy headphones or external speakers
Jan 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
I get a Post audio message on boot up/but no bootup
i have just thrown out 3 ASUS boards for various problems. they seem to last approx 18months before they die.
video output goes wrong, cpu socket errors, all sorts of problems and a rubbish tech support at ASUS does not help.
Feb 23, 2009 | ASUS P4P800-E Deluxe Motherboard
3 red lights of death upon startup
well if your system is under the three year warrenty your best and cheapest bet is to call and have it repaired.
Things to check would be making sure your psu has an ember light and is getting good ventilation check the p.o.s.t by holding down the sync and power button at startup. but i usally find that replacing the mobo is the fastest way to solve this problem. If the GPU gets very hot it causes the mobo to flex causing the lead free solder to become loose and break.
Dec 01, 2008 | Microsoft Xbox 360 Console
Maximum RAM not achiveable for KT4V
What Operating System and revision are you running?
I don't believe that XP 32bit (not sure about 64) will recognize 3GB of RAM, but Vista will as long as your MoBo (Mother Board) supports it or possibly even more than.
My Asus MoBo will utilize 4GB but Vista 32bit will only utilize 3.48GB or so, and Vista 64bit will take up to 8GB if the MoBo will.
Let us know what O.S. you're running?
Mar 12, 2008 | MSI KT4AV-L Motherboard
Will not start
I'm guessing that your computer was not working before the PSU change....
To find out what your problem is you have to Eliminate as many possible sources as you can, hence remove all your PCI cards and drives, (not your graphics card though, memory or CPU)
Check boot again... if it still fails to boot then it's either the CPU the MEM or the Motherboard....
if it does boot then plug in some of your cards, (but not all) and check again.... if system fails again, systematically check each card that you re-inserted.. this should help you find the culprit...
Nov 20, 2007 | Intel D845GVSR Motherboard
Intel D845GVSR Motherboard Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
