Question about Canon PIXMA iP3500 Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
My Canon ip3500 is one year old and seen minimal use but now BLACK will not print, all other colors fine. I have tried replacing the cartridge and running both normal and deep cleaning proceedure several times with no result. @audiogeezer: Did this fix succeed? my black started missing every other line and (against my better judgement) I took out the print head (?) and noticed that around the black nozzle (?) there were two bunches of lint and dried ink built up. I carefully cleaned this off with a cotton swab and then put everything back together. Now the printer misses every line, ie, no black printing whatsoever. I tried to print about 100 pages, but no workee. I'm starting to dislike my canon printer.
Try wiping the print head with a soft damp cloth - it works for me.
Posted on Oct 03, 2009
My canon iP3500: Black print comes out patchily, despite many attempts at deep cleaning, Each time I deep clean, a couple of pages come out with the black print OK, then it goes patchy again.
It sounds to me like your cartridge nozzles are clogged. That's more common with recycled or refilled cartridges, but it can also happen with new cartridges if they are older. If you just purchased the cartridge you could try to return it. Otherwise, I would try to continue deep cleaning and nozzle checks until it starts to print. It takes a lot of ink, but sometimes that's the only way to get it to print. Usually it will work eventually. Do a nozzle check in between each cleaning and deep cleaning.
Feb 06, 2011 | Canon PIXMA iP3500 Printer
I have an 8-year old Canon i9100, and have just installed my third brand new Print Head. It worked fine for one month, then the black started fading and then just stopped printing. All the other colors...
It is probably a bad purge assembly, when it doesn't clean or prime the printhead properly you have the problems you are describing. There are 2 sections in the purge assembly, one cleans color and the other cleans the black. Sounds like the black pump is worn out. The part runs around $30.00
Jun 29, 2009 | Canon i9100 InkJet Photo Printer
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
The black ink will not print on my canon pixma ip4200
printer head problem remove ink put about ten drops of alcohol in where the ink goes in run clean cycle ten times
Mar 29, 2009 | Canon Office Equipment & Supplies
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
Black ink will not print with canon pixma ip90v
Try sending Canon an email through their support website. I had same problem exactly, mine is 1 year old. They sent out a replacement unit for me today. It's worth a try.
Jan 30, 2009 | Canon PIXMA iP90v InkJet Printer
My printer will only print in magenta or black. It has two cartridges one black one color. I have preformed a deep cleaning and same result
Even in the test page there only magenta and black, then ink of the others colors are dried up in the cart you need change the color cart then try to print ...
Good luck...
Dec 23, 2008 | Office Equipment & Supplies
Canon PIXMA iP3500 Printer Logo
573 people viewed this question
old marine
old marine
