Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Clogged filter I have a Maytag JetClean EQ Plus (model number MDB9150AWS) and the filter under the lower arm is clogged and I don't know how to clean it. I can remove the filter, but it has several "windows" covered in mesh in which I can see debris, but I can't figure out how to open these "windows" to clean them. And how can I prevent the clogging to begin with?
  • 1 more comment
  • flynnjacobs May 30, 2009
    The particles are too big to be cleaned out just with running water. The gunk gets in...just can't see how to get it out!
    I can't seem to find the plastic cover that hides the cutting blade. Is that on the filter itself?
    Can't find the cutting blade. I did remove the spray arm and removed the filter...that's where I'm stuck. I have the filter in hand, but can't figure out how to clean out each filter window, which all appear somewhat full of gunk. The filter screens allow water in, but not much else, so I can't rinse out the particles.
  • Anonymous Mar 27, 2014
    where is debris filter
    President:
  • 1,136 Answers
Hi, The mesh does not open. You will need to GENTLY clean each section with running water. Are you using powder or liquid soap?
The most common thing that plugs them is food particles. This unit is best served by pre-rinsing the dishes. The mess gets plugged to easily.
I hope this helps.
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    If you remove the spray arm, you will find more screws in a cover over the filter (probably torx screws)
    Remove them and the cover will lift off.
    Does this help?
  • Victor
    Victor May 30, 2009
    It should clean up with running water. If you have a soft brush, that might help loosen the gunk.
  • 332 Answers
There is a plastic cover it has little hole like a grate in it, you will need a 1/4 inch nut driver to get the cover off and inside there is a cutting blade inside for fod that might get by, poor some water in when you get it apart then run a cycle after cleaning with nothing in it
  • gary miller
    gary miller May 30, 2009
    it is probobly grease you can take a pocket knife of screw driver anything you can fit in there, if you have to take the bottom cover off the dishwasher, have a small bucket with you tak off the hose clame the flush the water thru ot push it with what ever you can get in there just be easy not to break anything
  • gary miller
    I have to agree with maytag man,, get like a tooth bruch and maybe a windex bottle and spray wirth hot soapy water and scrub at the same time and also rinse your dishes off more before putting them i the dishwaher it really isn't made to remve bi items it's just pressure water, no scrubbing pads,
Maytag jetclean dishwasher eq plus
What is the model number?
Jun 04, 2013 | Dishwashers
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
Maytag Jetclean Dishwasher EQ Plus, Model MD87100AWW making grinding noises 20 minutes into wash cycle.
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
Feb 28, 2010 | Maytag Dishwashers
Our Maytag Jetclean Dishwasher EQ Plus will not turn on (MDB9150AWS) and we cannot find a repair manual to troubleshoot through the problem. Maytag does not offer repair manuals on this model. Any...
Try this. From what I have found Maytag discontinued the Repair manual but it appears that all MDB and MDC models fell under this one repair manual.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47135
Oct 10, 2009 | Dishwashers
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 | Dishwashers
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
1,096 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
