Question about GE PFS22SBSSS Stainless Steel French Door Refrigerator
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
  • Kenny Suchet Jun 02, 2009
    You are correct! There was ice build up. I left it off for 24 hours, enough to defrost, and have had no problem since. I had received advice that the condensor seal was broken and the condensor needed replacing at $400 - $500. Glad that I waited. But also wonder what would have caused ice build up in a six month old refrigerator which ought not to be dirty yet.
  • 1,543 Answers
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
Posted on May 31, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Jun 03, 2009
    Ice build up can be caused by an air leak. (door hitting something so it doesn't close all the way, ice cube holding the dispenser flap open, kids holding the door open for extended periods of time waiting for some good food to magically appear, etc.) Some times there are service bulletins which might address a problem in a certain model also. In your comment you stated that the refrigerator was only 6 months old. If your problem re-appers, I'd call for warranty service. (if still under the one year mark)
    By the way, generally, when we save a person $400 - $500 we do expect a 4 diamond Fix-Ya rating.
Loud buzzing from samsung french door fridge
Hi Debbie , sound like the evaporater fan blade is hitting the ake the back panel of the inside of the freezer and with the refrigerator off take off the blade and put back on . If that doesn't help replace the fan motor and blade . GOOD LUCK APPLIANCES R EN
Apr 28, 2014 | Frigidaire Professional 27.8 Cu. Ft....
Loud buzzing from freezer
icemaker wont work in fridge. the buzzing sound might be the water solenoid operating and waiting for water level sensor to be happy. solenoid will make a loud harsh buzz check water supply to back of freezer and see if there is a lever on icemaker you can lift up to turn off.
May 16, 2013 | Frigidaire Professional 27.8 Cu. Ft....
MY FRIDGE IS NOT COOLING
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | GE PFSS9PKYSS (285 cu ft) Bottom Freezer...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
See all GE PFS22SBSSS Stainless Steel French Door Questions
GE PFS22SBSSS Stainless Steel French Door Refrigerator Logo
250 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
