Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
No sound output - pioneer DEHP6700MP
I'm trying to install this in my camper. It powers up fine, dislpay showes a spinning CD, but I get no sound. The speakers, wires, connections and ground are all good. The only output is when I either pull the fuse or disconnect the yellow power wire. I get a split second of music> It does Not happen if I disconnect the red wire only. Any ideas?
  • 87 Answers
Sounds like a grounded speaker, disconnect each speaker and see if the sound comes back on through the remaining speakers connected. Its sounds like it is just in protection mode from a chssis ground. I hope this helps!
Posted on Jun 03, 2009
CDJ-800 Mk1 No sound output!!!
Not true! CD channels don't require a pre-amp and the cartridge for a turntable does. I suspect that when the power went off the mixer was still on, so that when power was restored it came back on. However this resulted in a surge inside the unit. Magnetic cartridge pre-amps are often very sensitive to this kind of thing and will sometimes fail, while everything else works fine. This would result in no sound from the record decks, but sound from CD players etc.
Apr 13, 2013 | Pioneer CDJ-800 Turntable
I recently hooked up my pioneer cd player in my car and when i play a cd it works fine for awhile but then the sound goes out. i double checked the wiring and the battery and its all connected right. the...
Hi:) Sound like the pre-amplifier transistors are burnt out if you hear no sound at all. If you can hear a very fate sound then it would be the Output amplifier IC's. If you are using a separate output amp check the amp.
Mar 16, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
Xtreme Sound WMS336 CD PLAYER NO SOUND CAN YOU HELP ME THANKS
im install cd player for my car, but not sound came out at all. removed it out, try check for connection, but everything was fine. then i did try play around for speaker 's wire speaker. i saw blue ( power ant) just connect to nowhere. then used blue wire to connect for output speaker, then sound show up. but rerarely to heard. cuz sond was too low. even volume was max. i thought maybe they need for more ground to run out put, or sound chip 40 legs is gone. ( need to replace for it?
Feb 13, 2011 | Xtreme Sound WMS336 CD Player
Help pioneer dehp6700mp front panel stopped working CD player plays if a disk is inserted. The tracks play sequentially, but only the volume on the front panel accepts input.
you can try cleaning the contacts of the face and subpanel with qtips and rubbing alcohol or a pencil eraser. if that doesn't work, you may have a bad switch.
Jun 09, 2010 | Pioneer DEH-P6800MP CD Player
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
Cd not playing
Instead of tapping it try hitting it.
Nov 01, 2007 | Pioneer CDJ-1000MKII CD Player
Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
436 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
