Question about Mtd Garden
The engine doesn't start. I didn't use it for several years. It started and ran well for about an hour; when I shut it off, I could not restart. I have tried the obvious...new plug, putting started
I have a Briggs & Stratton 135202 engine on a tiller. I did not use the tiller for several years. Last week I started it up and ran it for about an hour or more. It worked well. I shut it off for 15 minutes or so and have been unable to restart it. I changed spark plug, tried starting fluid both in the carb and by taking out the spark plug and spraying it in. I get a spark, I can see the starting fluid burn. But, it won't even begin to start.
  • wmrosso May 31, 2009
    Thanks a lot!
  • 1,040 Answers
You need to give the carburetor a good cleaning, as well as the air filter. Chances are the carb. will need a new carb. kit since it has been years since you last used it. If you need tips on how to clean the carb., just let me know.
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker May 31, 2009
    Thanks for the rating wmrosso. If you should have any questions about drywall finishing or patching, or know someone who does, put your questions to Tools-Building & Power-Hand Tools at FixYa.com
    Thanks Again,
    Jim
Premature power down.
Check for loose or corroded power connections.
Jul 12, 2013 | Lowrance LCX-113C HD GPS Receiver
Truck shuts off while in park idling.
Your car is 18 years old. It's likely history. Sell it as is for what you can get.
Jul 15, 2017 | 2000 GMC Yukon Denali
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
My sidekick will just die or barely run it died
last year, OBD1 car (dumbb ECU)
no scan tools for it
if you run on the road with that hack , and wreck
expect a nice fire. fuel fire.
if you used a voltmeter and say 12vdc there, all hotwiring stuff
need not be done. (
it stalled (misfire)
and then would not what? start but cranks ok?
4wd?
3sp ,4sp auto or 5speed stick
16v engine or 8v, both are G16s but EFI radially different.
16v is MPI with 4 injectors, 8v is 1 injector TBI
try a new
cap,.rotor spark wires and spark plugs yet?
cant burn fuel with bad spark
i guess the cam bent did not slip as it run ok later, but is 60,000 mile belt. and will slip ignored.
next time it stalls
check headlamps they work, and all electric
then see if CEL glows key on, i must or ECU lost power
it has 3 fuse that can rust, IG coil, FI, and DOME.
the CEL must glow, is first checks.
Mar 21, 2017 | 1995 Suzuki Sidekick
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
2004 titan engine shuts off without warning. usually restarts ok but sometmes won't start until you wait 5 or 10 min. At First I thought it ran out of gas, but guage showed 1/4 tank double checked this by...
Did some research for you on this problem. Go to this Titan forum link I am sending you.....First post sounds a lot like your problem. I'll still look around and make some calls....
http://www.nissantitan.info/forum_posts.asp?TID=2726&PN=1
Nov 27, 2009 | 2004 Nissan Titan
19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
Mar 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Oct 24, 2008 | 1994 Pontiac Bonneville
Garden Logo
537 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
