Question about Craftsman 25cc Gas Line Trimmer
Broken pull cord
The pull start cord on my weedeater broke and I cannot figure out how to get into it to replace it how do I get the clutch off a craftsman 358.791030 so I can replace the pull rope
  • 27 Answers
Ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
Posted on May 31, 2009
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
I have a Husqvarna 125L weedeater, New Fuel, has spark but will not start. Pulling the starter rope makes me feel that either I have a compression problem or a clutch problem it is just to easy to pull. I...
Hi there. Firstly remove the end with the starter cord and make sure the fly wheel is opening when you pull the cord. If not lubricate it until it frees.If it is working then it could be just the carb gaskets need replacing or the worst case is that the piston is broke and may need sorting.
Oct 05, 2013 | Husqvarna Forest & Garden 125l 18" Gas...
I need to know how the clutch works as I believe it is broke. The engine is an EZ fire 25cc craftsman on my weedeater/cultavator.
The clutch is centrifugal, if the clutch is broken it will most likely be hung up and not disengage making it difficult to pull the rope. Please let me know the model number xxx.xxxxxx and more about the symptoms.
Mar 23, 2011 | Craftsman Garden
I have a Troy Bilt Weedeater Model # TB415CS Here is the problem my wife decided to use this unit while I was at work one day and broke it. When I go throught the start up routine and go to pull the start...
If the rope recoils back into the starter, at least the starter spring is not broken...but...if you can break the unit down to where you can get a good look at it, you may find that the ratchets on the starter pulley are not engaging with the pawls on the flywheel...The pawls are spring loaded so they engage and then drop out of the way when starting, See if you can break the machine down to that point and post back,
Aug 06, 2010 | Troy Garden
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Broken pull cord
You have to take four allen screw out of the plastic that holds the engine on. There is also one by the spark plug that needs to come out. Once the engine is loose, you have to unplug one wire and unscrew the other. Then the engine should come off. Then loosen the two allen screws holding the pulley in and it will come out.
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Clutch
Two things, The rope pulley has lugs on it for the flywheel pawls, the lugs are worn off mainly due to pulling the rope before the pawls engage. replace plastic pulley..
the flywheel pawls are siezed in the run position full of dirt or rust clean and free up.
Jan 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman 25cc Gas Line Trimmer Logo
952 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
