Question about Samsung Digimax S630 Digital Camera
Not powering on
When I turn it out the green light will blink...and then i hear a little noise and it will shuts its self off. I have new batteries and actually have used several different batteriesw and still not working. I love this camera and actually its my dads so i really need to fix it before i give it back!!!
  • 75 Answers
Re: not powering on
Remove battery for a minute and insert it again.
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Scroll down to Battery Type
Two options under Battery Type:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Posted on Nov 30, 2007
0 characters
3 Points
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Digital Cameras
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Camera won't turn on
If when you press the power button the little green light on the right blinks it indicates that your circuit board is still ok. It would most likely be a bad lens unit. If you press the power button and the little green light does not blink you have a bad circuit board and it needs to be replaced.
Jan 24, 2008 | Casio EXILIM Card EX-S770 Digital Camera
It won't power on
Batteries are too low. Install new alkaline batteries or better yet metal hydride batteries that have been fully charged first.
Jul 23, 2007 | Samsung Digimax S630 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Camera wont turn on!!! i hear gears turning
Fuji Technical Support team website is the place to ask for further advice. But if the camera is more than a ear old - replacement is the only remedy.
Jul 01, 2007 | Fuji FinePix E510 Digital Camera
Samsung Digimax S630 Digital Camera Logo
Top Samsung Digital Cameras Experts
Are you a Samsung Digital Camera Expert? Answer questions, earn points and help others
