Question about D-Link AirPlus Xtreme G DI-624S Wireless Router
ROuter does not work
Cannot work wirelessly.  host name is NIS-962993094A.  Have unplugged router, have computer hooked directly into modem and it works so it has to be router issue - does it need to be reset, how
  • marnal Nov 12, 2007
    I bought a DI-624s router a few weeks ago and got it set up and running okay but am just now beginning to have problems with it.
    I have the problem above that I now cannot connect wirelessly- my computer is not picking up any signal at all coming from the router. I can connect fine by ethernet cable so know it isn't the connection or modem that is the problem. I have tried a few things recommended by different people/ sites but just can't seem to get a wireless signal from the router.
    Any help would be much appreciated.
  • 43 Answers
Unplug the router from computer and modem, (make sure the router must be powered on ), now at the  rear side of the router there is a small reset buttom,,, press it and hold it for 30 seconds,,, (you  can use a pin or a ball pen for it )... now fater 30 seconds,, power off the oruter and modem.,.  plug the oruter as it was before,,,,,,,,,,,,,, mow start the modem first ,, once the modem is up,, (all lights on the modem are back) then start the router... now check it should work.
good luck.
Posted on Oct 23, 2007
Had water in the basement and even though the router cord was not affected, the pc kept saying a cable was unplugged. I've tried all the usual - unplugging all the cords, waiting and turning them back...
here is the manual page. since you said you had water in the basement but you didn't say if the computer got wet. or if the Linksys got wet or if its just ...well rather humid! If you have one computer and it hooks directly to the modem and works then you know that the computer works and the modem works. if you then UNPLUG modem, and unplug router ( BOTH from the wall not the ethernet or lan from the computer and other devices.) then re plug in modem then router. then give it 3 minutes if it still doesnt work go to command promt type in ipconfig if it shows you numbers then it is communicating. something like
if it is not lighting up at all on the router the put it in a dry place for a while.
Jun 14, 2011 | Linksys Wireless-G WRT54G Router
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
I have a modem hooked up to one computer in my room, but my mom wants internet on her computer in her room, so I went to WalMart and they gave me this and told me it would work. However I really doubted...
You have mentioned that you have a modem connected to one computer already, if you want to access another computer from a different computer through a wireless adapter then you need a wireless router or access point to transmit the wireless signal, because the Belkin N150 Wireless USB adapter which you have bought is just a "receiver".
If you have router already connected to your modem then please give the brand name of the router you have
Thanks & Regards,
Jan 06, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
My router shows no connectivity.
Take your ethernet cable from the wan port and plug it into the lan port.
Nov 16, 2009 | Linksys Wireless-G WRT54GS Router...
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
I moved my computer - unhooked the modem and wireless router and
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
Linksys WRT300N router issue
you have to power down all three items , turn on the computer then the modem then the route if this fails hit the reset button on the modem this shoul work for ya
Dec 25, 2008 | Linksys WRT300N Wireless Router
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
DI 624- Cant connect from router to computer
Hi mark - please don't rate this til it's fixed. Hook it up the way you had it. i.e. modem>router>pc. Try it, probably won't work. Unplug the power on your modem and the router. After 60 seconds plug in your modem. When all the lights return to normal (except the activity light), plug in your router. Give it 20 seconds or so. Try it and let me know what happens. Thanks.
Aug 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Linksys wireless problem
hiya krazy327... sorry to hear about your prob.. we,ve all been here at some point!
Can you let me know if it is one specific computer that the problem is with?
If so .. how are you wired to the router "True" wireless or usb/ethernet gateway from the router?
Regards Faggly
Mar 18, 2008 | Linksys Wireless-G Broadband Router
D-Link AirPlus Xtreme G DI-624S Wireless Router Logo
1,082 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
