Question about Logitech V10 Computer Speakers
Logitech V-10 speakers makes a loud hooting sound when pluged in.
Everytime I plug in the USB cable into the speaker from the computer, there is this annoying hooting sound, really loud, and nothing seems to work except to unplug it, it doesn't stop until its plugged out. I tried to change the volume, that doesn't work and I muted the mike, because the sound is like the sound when a mike is too close to a speaker, but that doesn't work either.
Can anybody help me please? Can it be the drivers?
Open SKy
  • 620 Answers
SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
Posted on Dec 26, 2007
SOURCE: No sound
Make sure you've got your V20's set as the default sound playback device.
Control Panel -->
Sounds and Audio Devices -->
Tab 'Audio'; select 'Logitech USB Speaker' in the dropdown list in the first item on the tab.
just a thought...
Posted on Jan 01, 2008
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
Posted on Feb 18, 2009
  • 10 Answers
SOURCE: I have Logitech X-230 speakers. The left speaker
Posted on Jul 18, 2009
  • 995 Answers
SOURCE: Logitech Z4 sound from one side only
Reconnect all the wirings in your speaker set. Be sure you connect all the cords properly.
Posted on Nov 03, 2009
We connected our z 5300 speaker to a new computer. and get no. sound. Is there a driver that needs to be installed. the last computer no longer works.
Did you open your speaker ICON and check to see that you don't have the audio muted? I have seen a lot of customers complain that their NEW speakers don't work but they have their audio set to mute.
Mar 06, 2011 | Logitech Z-5300 Computer Speakers
How do i attach the speakers to my computer
The manual for you speaker system is located here;
On page 2 of the manual it says that all of the speakers plug into the subwoofer, then the subwoofer is pluged into an ac power supply, then # 4. on page 2 of the diagram shows that the Audio input cable to your PC is the green, black & orange plugs!!!!! YAY!!!
If you do not have a Dolby 5.1 sound card with green black and orange plugs, you will have to buy one. The can be had for a little as $15....
-----------------please vote 4 thumbs up 4 me!!!--------------------
Apr 24, 2010 | Logitech X-530 5.1 Speakers
My dell computer will not recognize the logitech speakers. I think it is something to do with the usb plug in versus a normal "jack" type plug in. I am using Vista as my OS>
Ok firstly make sure that the the speakers are connected to the green port at the back of the system tower. connect the usb cable to the usb port.
check with a headphone if there is sound . If sound is present then connect the speakers as above and then click start control panel - sounds - on this screen see if the speaker icon has a green check mark beside it , if not then click on the speakers and click use default device option present at the bottom of the screen. This should fix it.
In cases where the screen is greyed out .
strt - rgt click on computer - manage - device manager - audio device - chcek if ter is a yellow ! or red X beside it al;so check if you see other devices on screen
You could reinstall the audio drivers from the dell website for a DELL desktop . Reinstalling audio drivers should fix it.
try using the speaker on other system .
Hope its informative :)
Mar 31, 2010 | Logitech X-120 Computer Speakers
No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
if you still have a problem try
Hope this helps :)
Sep 15, 2009 | Logitech R-10 Computer Speakers
Logitech X-540 limited sound
why dont you have them all hooked up? I have the same speakers but I the model that only has 2 speakers. Try pluging your audio cable in the front where you would plug head phones in. Assuming that this is a desktop.
Jul 24, 2009 | Logitech X-540 Computer Speakers
No sounds on my speakers
1. Power to the speakers (make sure they are plugged in!)
2. Make sure the speaker line is plugged into the correct port on your sound card. The connector should be green and possible the port will be green to.
3. Double click the little speaker in the bottom right of the screen (assuming you are using XP/VISTA) and make sure nothing is muted.
Post back with your results.
Jun 03, 2009 | Logitech R-10 Computer Speakers
Logitech x-140 speakers connection
Did you try the black plug? Also, look at the right hand side of the tray and see if you have a Speaker icon. And if you do have a speaker icon, make sure that your sound is not muted.
Oct 25, 2008 | Logitech X-140 Speaker
They Crashed
seem static electricty issue.
unplug computer from the wall socket and hold down the power botton for 10 sec. do the same with speakers. pluge back it should work.
hope it will help..
May 30, 2008 | Logitech X-240 Computer Speakers
Logitech R-10 speakers sound problem
in control panel, go to hardware and sound, click on realtech audio manager with your logitech speakers plugged in, and then you should be able to chose your speaker configuration. If that doesn't work, try going to sound, and configuring your speaker setup there. Realtech has different settings you can click on, including volume, as well as various equalizer settings which you choose if you want to sound like you are in a sadium, bathtub, etc.
Mar 09, 2008 | Logitech R-10 Computer Speakers
Only getting half the volume
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Mar 04, 2008 | Logitech Z-2300 Computer Speakers
Logitech V10 Computer Speakers Logo
91 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
