Question about Garden
Won't Start A Craftsman 12.5 HP Riding Mower The plug is clean The air cleaner is clean The oil is clean Has new gas Went to start it and I don't get anything, no clicking, motor won't turn over, no lights, the battery is clean and fairly new. It rolls free (not stuck in any gear). Blades are up and disengaged. I''m thinking maybe electrical of some kind ???
    Genius:
  • 1,055 Answers
Theres a 25 amp fuse inbetween the battery and starter, also check your safty swiches like the seat, clutch/brake and blade disingadged
Posted on May 30, 2009
My John Deere riding mower is not idling right it back fires through the carburetor I change the oil and put fresh gas in it and new spark plug and still does the same thing
The problem may be a dirty carburetor. Before going thru the hassle of removing the carburetor, I suggest you get a spray can of carburetor cleaner and a bottle of fuel line / injector cleaner. Pour about 12 oz.. of the fuel line cleaner into the gas tank. Take the air filter off and spray the cleaner inside the throat of the carburetor. Let the cleaner do its job for a few seconds. Disconnect the spark plug wire from the spark plug and turn the engine over a few times. You can repeat this a few times. Start the mower and let it idle a few minutes. During normal use the fuel line cleaner will clean the carburetor. I also suggest you change the gas filter before you clean out the carburetor. Check the air cleaner, and repace if very dirty.
Jun 01, 2014 | Garden
Fuses location for craftsman 26 hp 54" deck mower
Replace start fuse on right side of motor by oil drain plug.
May 04, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman 18.5 42"
Hi, does it have a fuel shutoff solenoid in the bottom of the carby? if so has it got a rubber tip on it? if so remove the rubber tip and try it as the rubber swells and restricts fuel flow. Also remove all carby jets again and clean down through them using some twisted multi strand wire and carb cleaner and air. Just blowing air through wont remove varnish deposits etc from the walls of the jets. Let me know how you go, regards Phil.
Aug 20, 2012 | Craftsman Garden
18.5 hp 42 inch cut, craftsman riding mower loses power after 10 min.
Us start here, remove fuel line from carb. Hope fuel runs out.
Check the direction of fuel filter. There arrows on it. Arrow toward
carb.
Aug 09, 2012 | Craftsman Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Lawn Mower begins then stops before in use
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Mine did this.
It means that either not enough gas is getting into the engine. The gas you pump in when you prime is enough to start the engine but not to keep it going.
There could be several things that cause this.
1. Old fuel:
Solution: Replace the fuel. Dump out the old stuff. If it is a year old it won;t work.
2. A dirty carburetor:
Solution: Clean the carburetor.
Easy carb clean:
Pull the bowl off and use carb cleaning solution to clean it. (you can buy carb cleaning solution a Wal-Mart in the automotive section. I have also heard acetone will work but I have not tried it.) Make sure not to loose the little parts like the pin.
Better carb clean:
pull the carb off the machine and clean each part with carb cleaner. There is a youtube video someone else posted on how to do this.
3. Your gas/air flow is not adjusted properly.
To check:
Pull off or out the air filter. Try to start it.
Solution:
If the machine runs longer there are two options: The air filter is dirty so replace it, or the air flow is not adjusted proberly. There should be a screw like thing sometimes called the "main jet" that you turn to adjust the air flow. It is on the carburetor side or bottom.
If the machine dies faster or won't start there is probably too much air flow and by removing the filter you added more air. Adjust the "Main Jet" as above.
Apr 15, 2009 | Craftsman 10.5 Hp 33" Commercial Cutting...
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
