Need Online source for turntable belt
Old belt is way too loose, large rubber band didn't work!
  • 69 Answers
How do I know if I need to replace the turntable belt?
Belts are like big rubber bands. If they wear out and begin to stretch with age, there is no longer enough tension to move the turntable. They may also start and then quit once it warms up and the belt gets warm and expands. See how loose it is once it has been running.
Dec 06, 2013 | Electro Brand Nostalgic Stereo CD Music...
Rubber band which turns the turntable has slipped off. I cannot figure out the manner it is supposed to fit. Can I fix it myself? This the third time it's happened. Each repair cost me 90 dollars.
Hi. Yes you can replace the belt yourself. Lift the rubber mat off the platter and notice the two rather large holes in the plater. Put your thumb and forefinger through the holes and pull the platter oof the turntable unit. Place the platter upside down and notice the inner rim which holds the belt. Place the new belt around the inner rim and replace the platter onto the unit. Now, with tweesers, working through one of the large hole, pull the belt onto the spindle motor. Once on, spin the platter by hand and make sure the belt does not slip off. Hope this helps
Apr 13, 2011 | Aiwa PX-E860 Turntable
I have the Philco suitcase Turntable CD player. Art No. 841.237. When I got it from my friend, she hadn't given me the ac adapter/power source. When I got it, I assumed she had given me the right one. I...
I don't know whether your philco is the same as my crosley, but I recently had an issue where the record player stopped turning and it bamboozled me to no end. After digging up the manual online, I found out that you had to lift up the tone arm and move it to the right (past the holding clip) until it clicked, and voila, the record player started spinning again.
I hope this helps!
Sep 20, 2010 | Philco (R) Classic Turntable CD Shelf...
Opening the PL-Z81 box after standing packaged for quite some time -I saw that the turntable had come apart and that there were four pieces - a silver dish (the turn table) --the rubber mat that sits on...
Ok! On the main part of the turntable should be a spindle, not the one in the middle! That if you put your finger on will turn. This is the motor. On the underside of the silver dish should be a flange. Place the belt round it and put the platter on the center spindle (the one in the middle). If the platter has a hole in it, grab the belt and pull it, while rotating the platter till you can see the motor spindle. Attach the belt to that. Put the rubber matt on and try it out.
The black piece is for 45's with big holes in them (jukebox ones).
PS if the platter hasn't a hole you will have to put the belt on the motor spindle first and then around the flange (try not to pull the belt to much).
Also some turntables pass the belt via a leaver that lifts the belt up and down for 45 and 33 speeds, others just change the motor speed.
Aug 23, 2010 | Audio Players & Recorders
A part came off and dont know where it belongs
You will need to lift felt on the platter section exposing the platter. Next you will need to pull upwards on the platter itself. The rubber band goes around the inside of the platter and onto the spindle motor. To replace, simply lift platter section of the unit, place the belt around the inside of the platter and replace the platter. Move the platter around till you see the motor and use some tweesers to pull the belt over the motor. Hope this helps
Apr 17, 2010 | Sony PS-LX250H Turntable
The rubber band fell off
Normally the belt does not go through any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platter inside, through the two large holes
Mar 27, 2010 | Sony PS-LX250H Turntable
Have a teac p-a 400 turntable,that was just given to me. i see a rubber pad that goes on top of turntable, the turntable made out of metal, and a oversized rubber band. I put the rubber band around the...
I'm guessing that the belt is too large (stretched). Normally it should be small enough to stay on the platter itself. Install the platter and place the belt around the motor hub (white plastic), If the belt is too loose, it will just sit and not turn the platter. Try a new belt first as that is the least expensive option to try.
Keep us posted.
Dan
Apr 12, 2009 | Audio Players & Recorders
Turntable won't turn
Hi!
Without any other information (and assuming you've checked to make sure there is power to the turntable and that it is turned on), the likely culprit is the belt drive of your turntable. Most, but not all, turntables have a "belt" that looks like a big rubber band on the underside of the turntable that connects the turntable itself to the drive motor. If the band has slipped out of place, stretched too far from age or usage, or broken, the turntable won't turn. To find out if this is your problem, gently lift the "platter" straight up (it should easily slide back into place) and visually see if the "rubber band" is in place. If it is stretched too far or broken, a new one should be availble form Teac or your local electronics supplier. If, by chance, you have a direct-drive turntable (unlikely), the problem will probably need professional work.
Good luck and please let me know if this helps!
Bob
Oct 09, 2008 | Teac Audio Players & Recorders
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
67 people viewed this question
 Grubhead
Grubhead
